Question about Fisher and Paykel GWL11 Top Load Washer
Have kelvinator smart drive 503, water won't run
This machine has worked fine until today but now my machine starts to fill, then just stop/goes for very short time. then stops and beeps, and leaves 2 time of wash lights on and the orange and red spin lights as well as the slow and hold light
help me please, my washing is in piles now.
    New Friend:
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Posted on Aug 13, 2014
  • 713 Answers
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Posted on Jul 05, 2010
  • 713 Answers
SOURCE: When using the smart drive 051 the machine
Hi just read your posting.Now when the machine beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which ones are lit.Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Posted on Aug 04, 2010
SOURCE: I have a Fisher & Paykel washing machine.
how does a single rotor position sensor look like?
Posted on Mar 11, 2011
  • 251 Answers
SOURCE: my fisher & paykel smart drive excellence 7.5
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Posted on Jun 08, 2011
SOURCE: the washing machine fills with
Fisher & Paykel GW612 - The short and spin light is ON, together with a beeping sound. Appreciate any help to retify this problem
Posted on Aug 07, 2011
Ski runs fine until stop and leave for a short period of time all four cylinders fill with water
check for a non-return flap in the exhaust system that should close off on stopping the engine to stop water being sucked back up the exhaust as it cools down
Feb 16, 2016 | Video Game Consoles & Games
Fisher paykel excellence 6.5
take out plastic pump something may be caught in impeller water level sensors control power supply to pump
May 22, 2014 | Washing Machines
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher & Paykel Ecosmart washing machine it was operating fine until a few days ago. It will suddenly stop and start consitently beeping 4 lights are lit in the following sequence x=on 0=off...
A 51 code idicates a diverter valve fault turn the power off at the machine but leave it on at the wall ,then measur the volts across the wax actuator.If a reading of 230 volts is achieved the motor control module has failed due to the valve & both will need to be replaced. Kind Regards Stefan
Jul 07, 2009 | Washing Machines
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
467 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
