Question about Kenmore 64952 Electric Dryer
No power! Tryed to use the dryer one day and there is no power. It is plugged in, the breaker is fine and the door is shut. I tryed to start the dryer in all positions, and it will not start! No heat, no sounds, nothing. Any suggestions???
  • 3 Answers
Re: No power!
The thermal fuse may be blown. The fuse is a white plastic item located behind the back cover on the blower box housing. It has two blue leads attached to it.
  1. Unplug the dryer.
  2. Remove the back cover.
  3. Identify the thermal fuse (white, two blue leads, one screw)
  4. Remove the two blue leads.
  5. Using a multimeter set to ohms, check the continuity of the fuse, it should "peg" the meter if the fuse is good, if the meter does not react, the fuse is blown.
  6. Remove and replace the fuse. Replacements can be found either online or at your nearest Sears.
Posted on Feb 02, 2009
0 characters
3 Points
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
I want driver for sound device
Power Source
  • Before delving into other potential problems, first check that your dryer is fully connected to a working power source. If the dryer itself is already plugged in, try connecting it to a different plug-in receptacle or try plugging another appliance that you know is working properly into the same receptacle. Keep in mind, however, that a standard electrical dryer requires a 240-volt circuit, not a standard 120-volt circuit. If other appliances don't work in the same plug, try switching your circuit breaker off and on, in case your circuit has a blown fuse. Continue your inspection of any possible power source problems by inspecting the full length of your dryer's electrical cord. Check that it isn't worn through or damaged at some point. If you do find that the cord has exposed wiring, shut off all electrical power before handling the damaged cord.
  • Door Sensor
  • Generally, a clothes dryer starts only when its door is firmly shut. Check that you have fully shut the door, with any latch fully engaged, before pressing the "Press to Start" button. The unit has to mechanically or electronically monitor whether the door is opened or closed, and if the door-sensoring device doesn't work, your dryer may not start. Inspect any physical sensor, which should appear like a small finger or protruding button in the door jamb, which you can easily depress. Check that it isn't broken off, bent or stuck. If other courses of action do not work, you might try replacing the door-switch sensor or actuator. It's usually located inside the dryer's main housing, near the frame of the door.
  • Internal Wiring and Mechanics
  • If none of the basic troubleshooting actions work, your dryer may not start because of more complex issues related to internal wiring or mechanical components, such as the motor. To avoid these more complex issues, check that you are keeping the dryer's lint drawer and exhaust duct clean; lint build-up is a major avoidable cause of overheating among mechanical and electrical elements. To narrow down the problem, start by checking the thermal fuse, which blows if the dryer overheats. It's approximately 1 inch in length, and is usually located at the back of the dryer, beside the exhaust duct. If it has blown, you will have to replace it.
  • please comment on these solution by saying how helpfull
  • Dec 30, 2010 | Dryers
    The dryer wont show any sign of power. The plug works fine
    Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
    After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
    If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
    Make sure that the control settings are appropriate, and that any buttons are fully depressed.
    Good Luck and have a nice day.
    Jun 21, 2010 | Frigidaire Electric Dryer
    We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
    Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
    Mar 29, 2010 | Maytag Dryers
    Dryer was working fine this afternoon. I tried to
    Check for a blown thermal fuse. It is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown thermal fuse and it will have to be replaced. Hope this helped and best wishes.
    Aug 06, 2009 | Dryers
    Dryer is getting Power but not coming on.
    Check the following---
    1. No power to the dryer
    Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
    2. Door switch / Door switch actuator lever
    The dryer would not start with a broken door switch. Replace the door switch if found defective.
    Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
    Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
    Jun 01, 2009 | Roper RES7646KQ Electric Dryer
    Dryer quit working - will not do anything when "start" button is pressed
    It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
    May 12, 2009 | Dryers
    Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
    Hello mdonettaYou said,
    Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
    yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
    If this does not work there are internal fuses that can be replaced!
    Let me know how it goes!
    Sep 19, 2008 | Dryers
    Kenmore 64952 Electric Dryer Logo
    105 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Richard Roth
    Richard Roth
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
