Question about Kenmore Cooktops
Glass top cracked
I have a Kenmore Elite Model 790.4670, the glass top is cracked and will need replacing. I was looking for information on installing a new top
  • 135 Answers
SOURCE: Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Posted on Apr 07, 2008
  • 161 Answers
SOURCE: Replace the glass stove top
Probably more than it is worth. Last time I got a price it was for around $500.
Posted on Jun 30, 2008
  • 161 Answers
SOURCE: broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Posted on Jul 01, 2008
SOURCE: I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
Posted on Nov 19, 2008
SOURCE: Replace JED8430ADB Ceramic Glass
First, you have to pull out the cooktop from the counter and remove the knobs.
Next, there are hex screws around the perimeter - do not remove the lowest ones on the front and the back (they hold the tray that the burners sit in) or the ones on the bottom (they help to hold on the blower assembly).
The final trick are two screws that are located in the downdraft plenum - there's one on each side (you don't have to remove the two in the back or the front - those are for small covers only).
The glass should lift out.
When putting the new glass in, remember that the plenum walls fit on the inside of the glass (you won't see the top of the steel).
Posted on Dec 04, 2008
I have kenmore ceramic top range model number 79096011407, the glass top is cracked and I want to replace it but don't know how it comes off the manual is lost. There are three screws above where the oven...
are u sure u want to replace the ceramic glass top,much beter to check the price of the unit, coz it is very expensive almost halt the price of the new one...dont try to replace it by ur self coz the glass cover is no waranty if u broke or wrong intallation,u waste ur money if hapen that,much beter to canvas first & call an expert tecnician to do it.
Sep 08, 2009 | Cooktops
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Ceramic glass stove is cracked
HI
You should be able to replace the top only.
Normally if this is your fault, it is not covered by warranty. Normally this would be if you dropped something onto it. This would leave like a star shap series of cracks.
If its down to manufacture, this should be covered under warranty. This damage normally looks like just one long crack, no impact mark.
Check with the manufacturer
Rob
Feb 18, 2009 | Cooktops
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Cooktops Logo
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
