Question about Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel
Control panel is locked will not unlock using code .keeps beeping
Clock displayed ..
underneath scrolls and states to hit cancel but when cancel is pressed it goes back into same beeping mode.. it appears panel is lock but will not unlock
  • 641 Answers
SOURCE: error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Posted on Jun 08, 2006
vest6
  • 196 Answers
SOURCE: F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Posted on Dec 30, 2007
SOURCE: fridgidaire smooth top oven lock model FEF369CGSD
WHAT ARE THE ODDS! I had the exact same thing happen to my oven on the same day; I Googled the problem and there was your post with the solution! Thanxs, you saved me a bunch of headachs.
Posted on Mar 12, 2008
  • 185 Answers
SOURCE: Maytag gemini f1-9 error
plug it back in and press the cancel button
Posted on Mar 31, 2008
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
Cycle starts but shuts off. timer keeps running. when we press option select we get LOC. when we hold start/cancel button we get 5 beeps and ESE
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 26, 2009 | Frigidaire Microwave Microwave Oven
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Logo
94 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
