Question about Sony KV-32FS13 TV
Channels the television keeps changing channels. the volume button on top of the t.v. will stop the changing until you release it. the channel down button turns up the volume and the remote does nothing to the t.v. the t.v. is about six years old and has been working great until today
Try unplugging the set for a couple of minutes then plug it back in.
Posted on Nov 24, 2007
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
How do you tune in a alba tv with no remote control
There is no way to tune it, the menus that you need to bring up can only be accessed with the menu buttons on the remote
Feb 28, 2010 | Televison & Video
Need code for dynex television, using a nexxtech 1519000A remote.
Programming with Code Search
1. Manually turn on the device (TV or
Cable box) to be controlled.
2. Press and hold the P (Program) button
until the red indicator stays on. Release
the P button.
3. Press and release the desired mode
button (TV or Cable). The red indicator
blinks, then stays lit.
4. Press the Channel Up button repeatedly
(up to 300 times) until the device to be
controlled changes channels. If you
accidentally overshoot the desired code,
press the Channel Down button to
backtrack through the library until the
device changes channels. Pressing
Channel Up changes the direction to
forward again.
5. Press and release the Enter button to set
the code.
If the device does not have a Channel Up
button, use Power instead. If you go all the
way through the code library without
finding the correct code the indicator blinks
a few times then goes off.
Feb 05, 2010 | Dynex 24" Standard-Definition Digital TV
I need the codes for the sylvania television as i replaced the batteries and then it stopped working my tv
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Jul 16, 2009 | Philips PM3S Remote Control
Remote codes for dish network remote?
1. Mmanually turn on the device (TV, DVD, etc.)
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quiclkly release the desired mode button 9TV, DVD, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device (TV, DVD, etc.) changes channel. The red indicator blinks once with each button press. If you accidentally overshoot the code required, use the CHANNEL DOWN button to backtrack through the library until the device again changes channel. Pressing the CHANNEL UP changes direction to forward again.
5. Press and release the MUTE button to install the code.
or try these
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917 good luck its one of these!
Oct 25, 2008 | Philips 20PF5120 20 in. EDTV-Ready LCD...
P61960
I was tring to remove the concave off my screen and came across a setting where you can make the picture larger or smaller. On the TV, not the remote, press and hold the menu button, press and release the power button, press and release the volume up button and release the menu button. P0 and V0 will be displayed on the screen press the volume up button until the V0 is V76. Press the channel up button until P0 is P11 and press the volume up/down button to make the picture larger/smaller. If you need to center the picture press the channel down button until P11 is P10 and press the volume up/down button to center your picture. I hope this helps
Aug 18, 2008 | RCA P61960 61" Rear Projection Television
Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Mar 22, 2008 | Philips 32PF5320A 32 in. LCD Television
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Sony KV-32FS13 TV Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
