Question about Printers & Copiers
I need a owners manual
Would you happen to have a copy of the owners manual for a KYOCERA KM-1815? if not do you know where?
Thank you
Marcelo Oliveira
Re: I need a owners manual
For lexmark x5470 model, im having a problem closing the keyboard in the front, please email at
Posted on Sep 09, 2008
  • Printers & C... Master
  • 1,113 Answers
0 characters
3 Points
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website;
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Kyocera 1815 la y sale error c6020
The error means - Abnormally high fixing unit thermistor temperature.
Can be caused by Shorted thermistor or Broken heater control circuit on the power supply board.
Jan 19, 2011 | Kyocera Mita KM-1815 All-In-One Laser...
Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
May 27, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Service Manual for KM-1815 Kyocera Copier
all km manuals are available from New Jersey Copy
contact tony@newjerseycopy for all mita service and op mans
Nov 01, 2007 | Printers & Copiers
Printers & Copiers Logo
319 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
