Question about RCA Televison & Video
RCA D61W20 Projection Television with ITC222 chassis Here is the whole thing , took this machine apart last night the mirror is in good shape cleaned the lenses, picture is much brighter now! However still have the reddish blue swatch in the lower left corner of the screen and about a third of the screen from the left has poor convergence and a 3D look to the picture and also warped lettering when using the guide in DirectTV. The right side looks fine. Jun 16, 2009 - Tried auto convergence with remote, did not try service screen convergence, however the auto convergence would not go all the way through. I was told If that didn?t work the convergence power supply board is the usual culprit. My question, Is RCA part number 264103 Convergence Board the convergence power supply board that they are referring to? Is this an easier fix then replacing both STK392-040 convergence IC's ?
    Genius:
  • 1,030 Answers
Unfotunatly the itc222 has no convergence ics it uses a series of trsansiitors. the fact that u have some areas of the screen clear may mean you need a technician to do a service alignment. when you go into setup does the convergence crosshairs move up and down and side to side on both the blue and red? if they do their may not be a problem with the power board. ONe more thing if you replace this board you will still need a technician to do a service alighnment
Posted on Jun 16, 2009
RCA rear projection 61
why did you take apart the lenses did you take other parts a loose. may you unpluged a conniction or you need to back trace what you did if it was working before you did it. did you open the tubes
May 28, 2012 | RCA D61W20 61" Rear Projection Television
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
MY RCA MODEL NUMBER D52W19 WONT TURN ON!
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 17, 2009 | RCA D52W19 52" Rear Projection Television
RCA ITC222 Board
Also replace CP150 and CP120 then check for an open 1.25 amp fuse. It looks like a little tiny brown box behind the composite inputs about an inch inward. We always change those caps regardless of the problem. GO GET EM TIGER. Let me know?
Apr 21, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
New Problem with RCA D61W20
Donna, the 52 and 62 inch are both ITC222 chassis so the parts are the same for both models. Did the solder get shorted when you instaslled it or perhaps the HOT was shorted, as usually only a dead short will cause that type of arching. If it didnt burn a hole through the circuit board, the board should still be salvageable. Please respond to this same post and let me know wether the board is burned through our not.
Jul 08, 2008 | RCA D61W20 61" Rear Projection Television
Doesn't stay on
power supply is bad needs replaced
Apr 05, 2008 | RCA D61W20 61" Rear Projection Television
D61w20 big screen tv
You will need the service manual to be able to properly align the new tube after installation, that will also give you important info such as discharging the old tube as well as removal instructions. Post the chassis number on your set and I can post the link to get a good service manual if you would like. rca are crossed by chassis number that should be located on the tag next to the model number
Mar 20, 2008 | RCA D61W20 61" Rear Projection Television
Televison & Video Logo
223 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
