I have two Fujitsu Split Air Conditioners which are leaking. One dripped water, the other has ruined the wall covering where water was apparently collection around it. Does this sound like something I will need a repairman for?
  • 43 Answers
I think the AC's are not levelled properly so their is a leaking or the water tray might be filled up
Posted on Jun 16, 2009
  • aviatoraeron Jun 16, 2009
Fujitsu split system
there might be a crack on the drain hose
Jun 01, 2013 | Heating & Cooling
I have a Fujitsu air conditioner, model # ASUI8CI serial # ACA010576. It drips water into the room from the right side. After switching off the air conditioner and wiping the water, I switch it on again...
chances are either the unit is not level or the drain hose is not pitched properly going through the wall when water is leaking is there water coming out of the hose outside
Jul 11, 2011 | Fujitsu 24R1 Air Conditioner
BTU is leaking water from the inside.
Take the cover off the inside unit and look for the drip pan under the evaporator coil. It should have either one drain in the middle of the pan or a series of smaller drains along the back of the pan. The drain(s) is probably clogged up and causing the pan to overflow into your home. Also check the drain line on the outside wall where the refrigerant lines come through the wall for a blockage.
Jun 14, 2011 | Sanyo 09KHS51 Ductless Mini Split Air...
Water dripping from airconditioner inside the house
Water leak is the common issue in split a/cs. Due to coil,air filter, drain pan dust blocked, less rpm of blower motor, short of gas.
If service for the unit is more than 4 months, please do it first. And then check rpm of blower motor, if less replace capacitor.
Check gas pressure. Must be 60 PSI @ 98*F, of ambient temp. If less than that find leak and arrest and do gas charging. Thanks.
Jan 28, 2011 | Fujitsu 24C1 Air Conditioner
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
LEAKING SPLIT TYPE AC
drain line is more and likely stopped up
Dec 02, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
162 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
