Question about Uniden Cordless Phone
Sounds like my phone is off the hook - fast busy
How can i get this fixed, all of my phones in the house are affected - even the ones that are not a part of this dual set. i checked to see if any of my phones were off the hook and they are not/ Help - i cant call out or receive calls
    Problem Solver:
  • 6 Answers
Go to the NID (network interface device) on the side of the house and open the customer side.
plug a telephone that you KNOW is working into the customer test port.
if the 'phone works then you have a different 'phone that is bad or a short in a jack or wire.
if the 'phone doesn't work (you still hear ROH tone or just battery but no dialtone) then the problem is with the 'phone company.
if something is messed up inside... unplug all 'phones and modems. if you get dialtone, plug in each station and listen untill you go back to off-hook... and then you will know what is shorted.
if you don't get dt with all the 'phones unplugged then you have a bad station wire or jack. disconnect all the station wires at the NID or other bridging block and test for a short with an ohm meter.
Posted on Jun 16, 2009
Busy signals on all handsets, cannot call or recieve calls
Are you refering to a cellphone or a landline phone
Sep 13, 2008 | Lands Phones
How do I unstuck my Phone from line in use?
unplug all the phones in the house, or go out to the NID (network interface device) on the outside and disconnect the "line" from the "network". It should have a standard modular plug. You should be able to plug a regular phone into that jack and see if the line has cleared. Chances are there's a phone in the house that's partially off-hook.
May 15, 2014 | Nortel T7316 Executive Business Phone...
Callers get busy signal, all 3 phones say extention in use or parallel line in use
Possible causes:
1. Another phone is off-hook besides these 3.
2. Bad house wiring - call the phone company.
3. Bad wiring somewhere between your house and the Central Office - call the phone company.
Sep 14, 2009 | AT&T 650530003417 Cordless Phone
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
Disabled phone line
Sounds like the answering machine is picking up the telephone line and not releasing it.
Hence the busy signal, cause the answering machine has the line off hook. It's like leaving your telephone off hook, the next caller will get a busy signal...
The answering machine might be bad... have you noticed that you were talking on the phone and hung up then the next call would be the busy signal? Maybe test this out.
Do you have the correct voltage to the answering machine, too much power or too little power can do funny things to telephone equipement.
May 12, 2009 | AT&T Lands Phones
Can't phone out.
 Maybe one of your phones (if you have more than one in the house) is on talk mode. If that's the case you might not be able to use the other phones because that one phone is "Busy"
Apr 07, 2009 | Panasonic KX-TG1033S Cordless Phone
Vonage customer, problem running through home phone wiring
Make sure you have disconnected the original phone line at the first entry point to your home. Even though regular phone service is disconnected (software) the original phone line carries some "noise" which can cause issues when trying to utilize existing phone wiring throughout the home.
Dec 02, 2008 | Lands Phones
Main line shows solid red light
Fast fix is to turn off the power on the cabinet and power it back up.
Carl
Sep 08, 2008 | Panasonic KX-T7633 Corded Phone
Got new phone, answering machine dead?
There is no two horizontal lines error description in user manual.
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Based on my experience, I think, maybe it is related to parrellel phone dectection. ATT 1717 already think, the system is busy or in use. The line voltage is too low when you hook up other phone.
Your house phone line maybe far from switch (3km to 5km).
Dec 28, 2007 | AT&T 1717 Digital Answering Machine
Uniden Cordless Phone Logo
873 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
