Question about RCA P52926 52" Rear Projection Television
I have a RCA P52293 52 inch TV. I want to use apple tv with it. Apple tv lists the following requirements. Is my tv going to work ? Compatible with enhanced-definition or high-definition widescreen TVs capable of 1080p/1080i 60/50Hz, 720p 60/50Hz, 576p 50Hz (PAL format), or 480p 60Hz,
  • terriecollin Jun 16, 2009
    I need more than an assumption. Can the RCA P52293 work with apple tv?
  • 583 Answers
Discussed the compatibility issues with apple sources. RCA P52293 will not work with your apple tv.its not compatible. thanks and plse do rate this solution.
Posted on Jun 16, 2009
    Genius:
  • 1,341 Answers
Due to the size of the tv I assume that it is pretty new and should be able to work with enhanced definition.
How do i connect apple tv to marantz 5040 TV with no hdmi port?
Apple says you can't, however, there is one solution.
First, Apple, and then using a HDMI to RCA Converter Box in the link.
Set up your Apple TV To get started with your Apple TV, follow these steps.
Here's what you need
And using an HDMI to RCA digital analogue converter
How to Connect Apple TV to an Old Analog TV
Dec 04, 2017 | Marantz Televison & Video
My sharp LC-32D4U won't play audio with Apple TV is there an audio cable I can buy to fix this?
The good news is that you can likely make a simple change on the Apple TV to make it compatible with your existing TV's sound processor. Check out the following Apple support article for further assistance:
http://support.apple.com/kb/TS5150
Jan 02, 2014 | Televison & Video
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
Jun 08, 2012 | Audio Players & Recorders
Does my RCA model #L32HD41 support Apple TV
Hi ctodd154, The newest version of the Apple TV (V2) only has HDMI out, and your TV does not have HDMI in, so no, it does not support Apple TV 2. But, if you can find a first generation Apple TV, you can use component cables to hook up the Apple TV to your RCA TV - in that case, it is supported. Alex
Jun 02, 2011 | RCA Audiovox L32HD41 31.6 in. HDTV LCD TV
Just bought a used apple tv 1st generation and it blinks yellow and white even after I reboot it. It also shows the apple tv with a blinking question mark on my tv screen. How do I fiix to make it work and...
[1] You can restore an Apple TV (1st generation)'s software from the main menu by selecting Settings > General >Reset Settings > Factory Restore.
If you are unable to reach the settings menu, try the following [2]:
  • Press and hold both Menu and down (-) on the Apple Remote for 6 seconds or until the status light blinks amber.
  • The Apple TV should Reset itself and show you a screen where you can select one of the following: Restart ,Run Diagnostics o rFactory Restore. Select Restart.
  • [1] http://support.apple.com/kb/ht3199 [2] http://www.methodshop.com/gadgets/tutorials/appletv-fix/index.shtml
    Jan 14, 2011 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
    CAN I USE HEADPHONES?
    Hello. Your tv has one audio output jack on the back. 1 x audio line-out ( RCA phono x 2 ). Go to any Radio Shack, tell them what you have [RCA phono x2] so they sell you the correct headphones.
    Regards, joe.
    Nov 23, 2009 | Sansui HDLCD-2600 26 in. LCD Television
    RCA P52926 52" Rear Projection Television Logo
    43 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
