Question about Black & Decker String Trimmer Cordless 12" 18V
At home depot I can purchase .065 line without the spool for my trimmer. Should I buy this line and, if so, is it fairly easy to rewind it back on a used spool?
    Problem Solver:
  • 6 Answers
It is fairly easy to restring trimmer. just follow the arrows on the spool.
Hope this helps
Tobaz
Posted on Jun 17, 2009
Where can I buy spool and line. Homebase sell a spool with all the right details on but does not fit my strimmed
Hi Brian:
Don't know where you are or what make and model your unit is.
At this end of Canada, Canadian Tire, Home Hardware, Home Depot, most have racks of product.
Apr 29, 2015 | Garden
NST1024 trimmer string come off spool when trimmer is turned on
Make sure the line is wound on the spool in the direction indicated by the arrow on the spool. If the line is wound correctly, the auto-feed mechanism may be damaged. You'll probably need to take it back to your retailer to get it repaired. Your trimmer uses .065 size trimmer line and can be purchased in bulk via PartsBuggy.com at discounted prices.
Oct 22, 2012 | Garden
REWINDING LINE ON MY ECHOSRM211 WEEED EATER
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ~~
Feb 14, 2012 | Garden
How to respool the line on grasshog electric grass trimmer
The empty spool can be refilled with 30' of size .065" nylon line. Make sure you run the line in the direction of the arrow embossed on the spool.
Sep 06, 2010 | Black & Decker 14" Grass Hog Xp...
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Sep 07, 2009 | Garden
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can't find replacement string?? And can't seem to figure out for sure the model # or # on the string?
Most line trimmers will take .065 line. you can get this at lowes or home depot. Be sure to rewind it in the direction shown on the spool.
Aug 30, 2009 | Garden
How do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Apr 09, 2009 | Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
278 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
