We have a router as above and we cant access it to change MAC addresses . It is set up to hold 20 MAC addresses. I have tried to connect it to laptp and enter its IP address and it should normally open to allow access to settings > We have a Hughes HX50 MODEM and 3 Netgear DG834PN Wireless Routers off it for different areas.. One of the area routers will not work . Any advice available ?, thanks
SOURCE: Connecting Ipod touch 8(GB) to Wi-fi BEWARE SPAM NUMBER +1-800-532-4187 BELOW
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
SOURCE: Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
SOURCE: Have a new Hughes net HN9000 satellite service and
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
SOURCE: Applying QoS to WNDR3300
You may stop what you are doing right now. Nothing you do will work regarding QOS and your Avaya IP phone?
Is this a hardware VPN, or a VPN remote phone? (vpn client on the phone)
Depending on what system you are connected to, an IP Office or a communication manager, there might be settings to do, but none of them are qos.
QOS is inserted on the LAN, once the packets leave the LAN and hit the open internet, there is no QOS.
You might be able to change the compression algorithm the phone is using, which might help.
netgear support software could be bad. The ipod might not be able to read signal. umm try restoring the ipod. then plug it to your computer let it recognize it and then before you add ANYTHING to it, go straight to the setting and put in the router number and everythign and see if it works. I know people hate it but restoring it usually works. Its just simple small virus's that hit your ipod through songs and stuff and it eventually makes everything stop working. So get back at me let me know if restoring it worked.
If you've forgotten the password to your Netgear router, then you're locked out from making any changes. The only way to recover a Netgear router password is to reset the device to factory default settings. You can then set a new password and recover your ability to configure the router.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Have you got the password?
