Question about HP 5069-4515 Keyboard
HP Deskjet 712c Printer will not print in black & white
HP Deskjet 712c Printer will not print in black and white, but prints color fine. B&W cartridge has been changed...twice.
Re-installed software and driver. Still won't print. Tried to update Driver, but says driver installed is the current one.
    Sergeant:
  • 199 Answers
You need to check the head of the printer, im sure is bad, it depends how old is the printer but the head on the printer goes bad if printer has not been used for long time or if you left the old empty cartridge seating inside for a lont time, you can do a head check on the settings of the printer and also do an alignment thank you
Posted on Jun 16, 2009
My DeskJet 712C will not print anything when I try printing in color, it will, however, print with just black when I set it to do so. How do I get it to print in color, too?
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 07, 2012 | HP DeskJet 712c InkJet Printer
I have an HP deskjet 5650 and just changed both black and color cartridges. Test sheet ran fine with color and black. Now I am trying to print a Print Shop color document and the printer will only print...
Click Start
Click Control Panel
Click Classic View
Click Printers
Select your printer
Right-mouse click on the icon
Click Properties
Set the printer to print in "colour", not just "black".
Aug 30, 2010 | HP DeskJet 5650 InkJet Printer
I have HP deskjet F4488 printer which is all in one method. but i have problem that whenever i am trying to print the color(document)page in black & white type but i cant get the black & white...
hi..
in when you click on the print botton a dialogue box opens which shows the print properties. in that you have to select the grey scale then only it prints in black and white
if my answer was usefull please vote me
Jul 14, 2010 | HP Office Equipment & Supplies
My hp 712c printer prints only the pink band when I run a color test. I have replaced the original cartridge. Any ideas about the cause and solution.
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
Jun 24, 2010 | HP DeskJet 712c InkJet Printer
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
Won't print in color
hmmm..that's a little weird..guess the settings for color are ok?
Aug 19, 2008 | HP DeskJet 940c InkJet Printer
Deskjet 712c
yes..that means there is something amiss with your print drivers or print manager.
www.hp.com is a good place to get new versions of each.
May 09, 2008 | HP DeskJet 712c InkJet Printer
HP Deskjet 712c prints only blank
I had the same problem and what worked for me was to make a PDF and then check the box "print color as black" I only say this is a fix because I was desperate. I realize this is a time consuming workaround. also if you are going to do this make sure that your printer settings are for Color but then the print color as black box is checked. hope that helps.....
Jan 25, 2008 | HP DeskJet 712c InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Computers & Internet Logo
322 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
