Question about HP Pavilion a450n PC Desktop
Monitor warning pc enter power saving mode
HP Pavilion a700y monitor HP f1503-
Took computer home from work,couple of months before I hooked it up.Computer starts but no XP image;monitor shows"entering power saving mode" computer continues to issue 5 second sound signal followed by 3 sec silence and same signal indefinitely.Power supply seems fine.Fans working.Electrical outlets/cables all fine.Took out battery same symtoms exactly.
What do you do when you can't get into windows on the screen?The monitor works fine on a friends computer.
Any advice will be sincerely appreciated regards Rick/Seattle
  • rbbach Jun 16, 2009
    Reco22 Thank you for the quick comeback and your advice.It's a wireless keyboard........not the one I used at work.I just tried another
    keyboard with wire same result. Would the computer be unable to boot to Windows with dead plugin port??.......I'm going to get a new battery today even though HP support said it should come online without the battery.(It didn't)
    Thanks again for your time/help any further info appreciated Rick/seattle
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Are you using usb keyboard and muse. if so your usb ports are dead
Posted on Jun 16, 2009
  • Reco Wilson Jun 17, 2009
    If the ports are bad then theres no connection and it can't pick up the signal if theres no connection
When I turn on the monitor, I get an error message: "Warning PC entering power saving mode", then it turns off.
Unplug your dekstop from the electricity then press and hold the power button on your desktop for couple minutes with out no power cable attached to it then let go of the power button then connect your desktop back to electrical outlet and press power button once that should give you display once it turns back on you can go into your power saving options and turn off power saver mode as its conflicting with your LCD sometimes this can occur if you have Norton antivirus installed
if after doing the power drain and still get same message then you can try using a different monitor if you have one for a test.
this issue is not with your monitor but with the PC has been stuck in sleep mode but the power drain should solve your problem.
Mar 01, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
My Monitor enters power saver mode
install the driver for that monitor on the laptop
Jun 21, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Pc entering power saver mde
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
May 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Dell computer will not work with an older HP monitor
no dell have set up there computers so you cant use othe appliances that arnt dell. so im sorry for the inconveince.
please rate my help to you.
thank you.
Apr 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
WARNING: PC ENTERING POWER SAVING MODE
sounds like a faulty power supply unit
Mar 24, 2008 | HP Pavilion a450n PC Desktop
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
HP Pavilion a450n PC Desktop Logo
551 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
