Question about Fossil ES9825 Wrist Watch
Changing battery Hi, I'm trying to change the battery in my fossil watch.  It's an ES-9836.  The ES9825 looks the closest.  I can't get the battery in all the way.  Can you help?
Re: changing battery
Generally, there's a small clip that can be held out of the way with a screw. You may need to hold it back, and tighten the screw in order to insert the battery. It may be enough to hold the clip out of the way.
Posted on Jan 22, 2008
0 characters
3 Points
Need to know what type of battery i need to replace mine
Energizer 379 Button Cell Silver Oxide Sr521sw Watch Battery
Oct 26, 2013 | Fossil ES9825 Wrist Watch
Size battery
If it's just the battery it will usually take a AG1/364 battery or SR626SW. The batteries are cheap if you buy it on ebay.
Hi! I have the fossil es-2795 and I dont know how to change the date and day because it does not match with each other when i change the time?
Go to
While Fossil do give a list of instructions, they are not given type numbers so you will have to sort through their list to find the instructions that are for your watch.
If you put the cursor over each of the descriptions in the list, the diagram changes to show a drawing of the watch that the instruction is for. This way you can quickly locate your watch on the list.
Apr 18, 2011 | Watches
What battery does the fossil fs 3105 watch take
It's actually a lot easier than that video shows. You're trying to represent a watch that is a PDA! To change the battery in your watch, you need to purchase a watch kit on eBay for about $15-$25, purchase the correct battery, watch a realistic video of changing a battery on Youtube, and then you will never need to pay more than the cost of a battery (a few dollars) to change your watch battery ever again! Sending it to Fossil takes time and money and you can do it at home with basic skills!
Jan 16, 2011 | Fossil FS3105 Wrist Watch
I have a big tic watch but after a battery change the digital number display on watch face no longer works,why?
Who changed the battery, you or a watch repair serviceman? Did you replace the battery bar after you replaced battery? Did you check and see if there was a second battery (some watches have two)
You may need to have it serviced. Or try Fossil at :
Aug 23, 2010 | Watches
Lost the battery for Fossil ES 8949 could you please tell me what battery I need for replacement
Please refer to above link for the replacement of your Fossil Watch.
Suggest to contact the authorized dealer.
Thank you.
Dec 24, 2009 | Fossil AM3425 Wrist Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossill Man's wrist watch FS4252
go to and click on custumer support that is where all the manuals are hope this helps
Nov 25, 2007 | Fossil ES9825 Wrist Watch
Fossil watch battery
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Fossil ES9825 Wrist Watch Logo
298 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
