Question about GE Dryers
GE DNXR47GW1WW Dryer is extremely slow to dry clothes (takes over 2 hours per load). The dryer does heat. Any suggestions?
  • 6,784 Answers
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective. (if this is a gas dryer, please disregard this statement)***
Posted on Jun 18, 2009
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Dryer takes hours to dry one load of clothes
I WOULD SAY YOUR DRYER NEEDS CLEANING OUT OR YOUR WALL VENT IS CLOGGED AND NEEDS CLEANING OUT-MIKE
Mar 04, 2009 | GE Dryers
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Ge dryer
i built these machines... before doing anything ...check your fuse box or breaker .... 240 v .... it goes out often ... if its not that ... its probably your element ... ...open your door and on the top of the opening ... there 2 screw ... take the top off then the front ... 2 other screws ...take out drum ...and check element ... its about 60 for a new one
Oct 09, 2007 | GE DWSR405EBWW Electric Dryer
Dryers Logo
244 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
