Question about Tissot Le Locle T41.1.317.31 Watch
Not sure how pusher B works my maual is for quartz
My pusher A has a mild click when pushed clicker B doesn't-
not sure i have a problem or not
  • 58 Answers
This is nothing to worry about :)
Posted on Jun 22, 2009
How do I set the time and how do I get a user manual.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resyn
step 1: follow the instruction 1 to set digital clock to 12:00.
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.
step 4: push the pusher at 3:00 to exit the sync mode.
step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jun 18, 2011 | ESQ 07301132 Aerodyne watch
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jan 14, 2011 | ESQ 07301132 Aerodyne watch
I have a bretling colt quartz watch and the hour regester will not reset
Try pulling out the winding crown,then press the chrono pusher.This will advance the chrono hands.Each pusher will advance a different hand.
Aug 13, 2010 | Breitling Colt Quartz 820 Wrist Watch
I have an ct1115 tag heuer aquaracer chronograph and the caps to the buttons on the side fell off easy fix? you can push them with your nail the watch still works etc. the covers are gone
The pushers sound like they have fallen off.This is quite a common problem.Take care as the watch wont be waterproof.The parts will need to be obtained from TAG and fitted by a watchmaker.Return the watch to an agent for them to attend to or find a watchmaker that can get TAG parts.
www.rolexrepairs.co.uk are specialist watchmakers that could help.
Regards
Aug 04, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
Setting time day date in ESQ Aerodyne
Jul 26, 2010 | ESQ 07301132 Aerodyne watch
Baume & mercier hampton city watch
Does the dial have "Automatic" wtitten on it". If it does then it's a mechanical movement. If it has "Quartz" then it requires a battery. If the watch isn't running perhaps it just needs a battery. This may also explain why the pushers aren't working. If it's mechanical the watch needs to be wound before the pushers will work. What are the markings on the subdial.
Jul 19, 2009 | Baume Et Mercier Hampton City Leather...
All functions have ceased to operate - the reset works fine but none of the buttons seem to function. this problem started all of a sudden, i assumed maybe a button was stuck but they all seem ok?
Pooky
Indeed the buttons (pushers or pusher contacts) may have been jammed internally. The are a small piece of metal which is pushed my a cylindrcal rod (which you are pushing the outer part of it into the pusher contact).
Sometimes the pusher contact may have come out of alignment. or did you change the battery yourself? did you a/c it properly? (metal tweezer from the a/c with the battery)?
Hope this helps or sheds so light on your situation
Jul 13, 2009 | Casio PRG-40T-7 Pathfinder
24 hour time setting to 12 hour
You can't! Trust me I have been dealing with watches for 2 years now and currently work in the industry as a watchmaker's assistant.
There are different settings for each different brand, Casio have there own configure and so does Seiko etc.
Best way I know is to push buttons to something happens. Please note DO NOT DEPRESSED ALL PUSHERS AT ONCE, this 99.99% of the time will reset the entire device!.
Usually there is a 'reset' pusher which will once depressed (either immediately or after a few seconds of pushing it) will flash, then you work out which one is the 'next' button until you get to the 12/24hr then press the Up or down pusher (usually but NOT always opposite side to the 2 previously menitioned pushers).
As for auto's or quartz that's another matter.
Hope this helps?
Jul 11, 2009 | Watches
How do I set the time on this watch
Try this link:
http://www.seikousa.com/#FAQ
Rate, please.
Mar 30, 2009 | Seiko Quartz Professional 200M Scuba Diver...
Tissot Le Locle T41.1.317.31 Watch Logo
51 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
