Sharp UX-P115 Plain Paper Thermal transfer Fax
Problem for Sharp UX-P115 Plain Paper Thermal transfer Fax
How to save numbers
By mback520 on Jun 16, 2009
i need to know how to save phone numbers to the machine i got it from a friend and it didnt have a manual
Solution #1
posted on Jun 17, 2009
Not Rated)
greg_margo
Rank: Guru
Rating: 91%, 703 votes
Your machine can store up to 30 numbers. To store numbers, use the following process:
  1. Press functioni button once
  2. Press right arrow > once
  3. Assign a two digit speed dial number or press the right arrow (machine will suggest a 2 digit speed dial number
  4. Enter the fax number (use speaker button if a mistake is made to clear)
  5. Press Start/Memory button
  6. Go to Page 28 in user manual
At this point, there's a chart for entering names for the fax numbers which can be found in the owners manual at this link: http://www.sharpusa.com/files/fax_man_UXP115.pdf
After the name has been entered, press Start/Memory button to Store and press Stop button to leave the process.
Best of luck and hope I helped.
Greg
Comments:
Jun 20, 2009
- Kindly rate the solution provided if you feel it fixed your problem.
Thank you very much.
Was this helpful?
Yes
No
Popular Solutions for Sharp UX-P115 Plain Paper
Questions and Unsolved Problems for Sharp UX-P115 Plain Paper
Do you recommend Sharp UX-P115 Plain Paper Thermal transfer Fax?
Answer
Answer
The paper is not feeding through the fax machine when a fax comes through because a rod (bar with a... (More)
Answer
i also need a new journal roll for my casio pcr-t2000 cash register. actually i need 2. one register... (More)
Answer
devido a net - precisaria modificar o tom e/ou pulse. por favor - veja se pode me ajudar onde... (More)
Answer
how to setup the fax machine on receiving mode.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp UX-P115 Plain Paper...:
Top Fax Machine Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Fax Machine Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
