Question about eMachines W5243 Refurbished AMD Desktop Computer - AMD Athlon 64 3800+ 2.4GHz , 1GB DDR2, 250GB
Power supply issue
I have bought a new power supply for my emachines w5243 its 950w. I bought to support the new graphics card i bought nvidia gtx 260, i plug everything up correctly turn it on but only stays on for second or less. Im really confused on what the issue is. Thanks
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
You could have bad hardware.
Posted on Jun 16, 2009
Boot up with nvidia gtx 550 ti help
Two things defect?
Or your power supply is just to weak or your voltage settings are wrong consult a technition where you bought the card.
Nov 04, 2013 | Evga 01g P3 1556 Kr Geforce Gtx 550 Ti 951...
Is not Reading My Geforce GTX 260 Card
What do you mean connect wire to graphics card?
A) Computer is to be OFF when connecting a monitor cable.
B) Computer is to be OFF, and unplugged from power; when plugging the power cable from Power Supply, into it.
You are also supposed to be Following Anti-Static Precautions.
What Power Supply are you using?
Manufacturer name, and model number. Post back in a Comment.
Motherboard requires about 150 Watts by itself.
That isn't including what the Processor (CPU) needs, Ram Memory needs, optical drive/s need, computer case fans need; AND what the Nvidia GeForce GTX 260 graphics card needs.
It needs 225 Watts by itself.
(Manufacturers usually state around 500 Watts MINIMUM.
This is in reality based on a COMPLETE computer system, and NOT just the graphics card itself)
What do I base that the GTX 260 needs 225 Watts?
(I see that as the -> Maximum, though )
A PCI Express x16 expansion slot on a motherboard, is only capable of 75 Watts of power.
That is why the additional power cables were brought out.
The 6-pin PCI Express power cable that plugs into the GTX 260, is capable of an additional 75 Watts of power.
The Nvidia GeForce GTX 260 requires using TWO 6-pin PCI Express power cables
That means 150 Watts of additional power.
75 Watts + 150 Watts = 225 Watts
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-260/specifications
"Supplementary Power Connectors -> 6-pin x2"
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
If you are using just one 6-pin PCI Express power cable, '
this = NO.
NOT enough power for the graphics card.
What will happen?
A) The PCI Express x16 slot connector oins, will burn
B) The gold plated contact pins on the bottom of the graphics card, will burn.
C) The connector on the graphics card, that the 6-pin PCI Express power cable plugs into, will burn.
D) The connector on the 6-pin PCI Express power cable will burn.
The graphics card will burn up.
Too little power.
IF, your Power Supply has enough power, and IF there are two 4-pin Peripheral power cables that aren't being used; you can use a 6-pin PCI Express power adapter cable.
Example of 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Example of 6-pin PCI Express power adapter cable, was shown in the Playtool link,
http://www.directron.com/pci03.html
(Connectors are white, and hard to see against white backdrop. You can enlarge all 3 views)
For additional questions please post in a Comment
Regards,
joecoolvette
Feb 23, 2013 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
Is p4c800 deluxe compatible with an nvidia geforce gtx 550 ti (1 Gb)?
The Asus P4C800 Deluxe motherboard uses an AGP expansion slot, for a graphics card, Jorgito.
http://www.asus.com/Motherboards/Intel_Socket_478/P4C800_Deluxe/#specifications
The Nvidia GeForce GTX 550ti graphics card is a PCI Express graphics card. Uses a PCI Express x16 expansion slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=356682&CatId=3669
No sir, is the answer.
A) http://en.wikipedia.org/wiki/AGP
B) http://en.wikipedia.org/wiki/PCI_Express
You need an AGP 8X graphics card.
Here is but one example,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161337
You also need to look at what your Power Supply maximum rated Wattage is. Then look at the system requirements for the graphics card, and see what the -> MINIMUM power supply requirement is.
For the above graphics card it is 400 Watts, OR greater.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600007850&IsNodeId=1&name=AGP%204X%2f8X
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Just for edification;
http://computer.howstuffworks.com/motherboard.htm
http://computer.howstuffworks.com/graphics-card.htm
http://computer.howstuffworks.com/3dgraphics.htm
Nov 25, 2012 | ASUS P4C800 Deluxe Motherboard
I want to purchase nvidia professional card suggest me compatible graphic card for my intel dg35ec motherboard.
Nvidia Geforce GTX 560 is a very good choice but could be on the edge for the power-supply so to be sure spend some on a better power-supply!
Mar 23, 2012 | Intel DG35EC Motherboard
Nvidia asus gtx 570
is your power supply giving the card enough juice?
Nov 19, 2011 | Nvidia ASUS ENGTX570/2DI/1280MD5 GeForce...
I want to install my nvidia geForce 5500 for win7 please help
insert the card into the pci slot on you motherboard turn your computer on the found new hardware should activate and ask you to install the drivers/software for it
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if you need more help with this post a reply
hope this helps you
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630932.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUsIncreases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630939.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
Sep 11, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Confusion over selection of graphics card
I don't think whether it's compatible or not is the issue with graphics card, what you need to make sure is that you have a good power supply for the cards' needs and that your motherboard has a decent FSB speed (Front Side Bus).
I've compared the specs of your motherboard to the graphics card. That looks abolutely fine, only other thing you'll need is a decent power supply, I suggest 750 watts or above as you will need 2 molex plug connections for that card. Isn't the best motherboard in the world for it but It's going to be better than the built in X3000 shared graphics you're currently using!
If you've got any other questions regarding this just give me a shout!
Craig
May 25, 2009 | Nvidia GeForce 9800 GTX,, PCI Express...
Bought a Nvidia Geforce 7800 GTX 256MB Graphics card
errrr.... do you mean the 6 pin pci-e power plug and lead that normally comes off your Power supply?
You can get converters leads that change the pinout of 5.35 HDD power to 6-pin pci-e but this is usually NOT RECOMMENDED for any GTX series of GeForce.
You usually need the dedicated PCI-E RAIL (with its own PCI-E lead/connector... or even better x 2 of them) on your power supply for these builds.
Once again.... i definately do not recommend converting one of your other power outputs to run a GTX. At best it will not work.... at worst (though unlikely) you may end up damaged your shiny new GFX card.
If you do not have a 6 pin PCI-E lead and plug running directly from your power supply to run this card.... you need one. Do you happen to know the model of your current PSU?
Mar 25, 2009 | Dell nVIDIA GeForce Go 7800 GTX, (256 MB)...
Which graphics card should i use
you cannot put a graphics card in your laptop. All graphics are integrated into the motherboard already
Dec 24, 2008 | Nvidia Computers & Internet
eMachines W5243 Refurbished AMD Desktop Computer - AMD Athlon 64 3800+ 2.4GHz , 1GB DDR2, 250GB  Logo
235 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
