I have a mastercool a/c and at the present time a/c wont work on low only on high any suggestions
    Sergeant:
  • 340 Answers
Replace control board
Posted on Jun 17, 2009
Mastercool accu-charge 2 scale
Are the terminals where battey connects clean if not they wont make the connection
Jun 01, 2016 | Mastercool MSC98210A AccuCharge II...
I noticed a smell coming from the mastercool and now the low speed and low cool does not work.
is it a burning rubber smell or a burning eletric smell. burning rubber smell will be a slipping belt. replace the belt and pullys. tighten belt. electic smell will be a bad thing. have tested by technition
Aug 12, 2010 | Mastercool 67680 Evaporative Cooler Air...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
Motor does not go from low speed to high speed If the motor is set to low speed it does not turn on until the high speed range is hit then it tries to go from stop to high speed and throws thw belt
MOST OF THE TIME IT IS THE DIGITAL THERMOSTAT OR LOOSE TERMINAL AT THERM. THESE STATS ARE TRICKY TO CHECK. LIKE WHITE ROGERS 4 WIRES CONTROL WITH A RED WIRE TO GREEN YOU GET PUMP WHITE YOU GET LOW YELLOW YOU GET HIGH AND SO FORTH. MASTER COOL DOES IT DIFFERENT SO YOU BUY THEIR TSTAT
Apr 21, 2010 | Mastercool 67680 Evaporative Cooler Air...
York 3phase compressor tripping on low currant microprocessor.
If the unit is single phasing this is not good for the compressor. Does the system have a phase monitor? If not I would suggest you put one in to save thousands of dollars on the replacement of the compressor. How is the oil level? I ask because this are not to run themselves out of oil.
Jan 12, 2010 | Mastercool 67471 Evaporative Cooler Air...
My motor switches from high to low over and over again
It sound like the low speed winding in the motor is bad.You will need to get a new motor.
Jul 24, 2009 | Mastercool 67680 Evaporative Cooler Air...
Low voltage wires
I just tested a mastercool control box and found these 4 control wire colors:
Red (24v supply)
White (pump)
Green (low blower)
Yellow (high blower)
The yellow acted as a common for testing when the blower was not on high.
Blower on low just green has 24v.
Blower on high green and yellow have 24v.
If there was a fifth wire added hopefully it would be a ground wire.
There was also the low gauge wires that were black, white, and ground that were not control wires and delivered power to the control box.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
93 chevy s-10 blazer 4wd High wont work
Transfer case module causes this, first disconnect battery then wait 1 min reconnect and try 4 high should work till you can get a trained tech to fix.
Jan 02, 2009 | 1993 Chevrolet S-10 Blazer
Noise on mastercool
had the same symptoms and found that tightening the squirrel cage set screws eliminated the noise.
May 23, 2008 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
