Question about Intel Motherboard
I ran the RegCure on the problem but went the
I ran the RegCure on the problem but when the computer restarted
the: C:PROGA~1/MYWEBS~1/1banbinMEPLUGIN.DLL the error returned.
    Problem Solver:
  • 6 Answers
Well Because For RegCure To Work You Have To Pay For A Registration Which Is Dumb So Instead I Use SpyBot http://www.safer-networking.org/en/mirrors/index.html Which Is Very Reliable And Free To Use And It Comes In Its Full Version Without Paying And What You Sould Do To Run This Is Download It Run It And Follow The On-Screen Instructions
Posted on Jun 18, 2009
Licence key for regcure pro 3.2.1
How do i find RegCure Pro license key 3.2.1 ? Solved Solved ....
RegCure Pro 3 2 1
Aug 28, 2013 | Computers & Internet
Tip
How to Erase RegCure from your pc system
<span><span> <p>RegCure is a registry repair tool that allows you to solve registry errors, such as missing dll files, damaged registry keys and corrupt settings. If you are no longer interested in this program, or prefer to install and use a different registry repair tool, uninstall RegCure from your<span> </span><a href="http://www.ehow.com/computers/">computer</a>. Uninstalling RegCure is a quick and simple process for Windows 7, Vista and XP users.<span></span><br /><br /><span></span> <span>Instructions</span> <ol> <li> <ul> <li><span>1</span> <p>Click the "Start" menu and then click "Control Panel." Click "Uninstall a Program" if you are using Windows 7 or "Programs and Features" if you are using Vista. Double-click "Add or Remove Programs" if you are using Windows XP. The programs window will launch.<br /></li> <li><span>2</span> <p>Scroll down and click "RegCure." Click the "Remove" or "Uninstall" button. If prompted, enter your administrator password and confirm you want to remove the application. The setup wizard will remove the program.<br /></li> <li><span>3</span> <p>Restart your computer to complete the process<br /></li></ul></li></ol></span></span>
on Dec 27, 2010 | Computers & Internet
I have two problems. I had System Mechanic 8 on my computer for a year. Nothing bad particularly happened but it was probably because I was running Regcure at the same time and I got suspicious when somany...
just format ur HD and re-install all software...
and use Tuneup Utility ( u can download it from my shared drive and u can also have it Fully working)
this is the best way to fix ur issue...
let me know..i will send u the link for my shared drive...
Dec 20, 2009 | Iolo Technologies System Mechanic...
Dell 926 will not print black and gives alignment error
Has this printer been sitting for a period of time? Inkjet nozzles will dry up...replace the cartidge, even tho it may be half full, it prolly has dried out
Jul 24, 2009 | Dell 962 Photo All-In-One InkJet Printer
RegCure did not work. Still no system restore. It seems to be locked on the Question '' how much space will this take'' Under Computer/Properties/system restore
well first of all you need to restart your computer in the safe mode with networking under the Windows Advanced Boot options
and then try running the regcure,
incase your computer is locked up,
Jun 13, 2009 | Computers & Internet
I had the C:Program/myweb2/bar/2.bin/m3plugin.dll
What is the problem? Most of these "Reg Dr" type products do more damage than good.
May 28, 2009 | Intel Motherboard
Verify that you have access to that directory
you need to do everythin as administrator.
login with Adminstrator/Password and you will be able to do that.
If you do not have, set it / obtain it.
Rate me Rate me!
Mar 17, 2009 | RTO Eset NOD 32 Antivirus System 3.0 Full...
CCleaner
RegCure has done it again!
pls follow these steps >>
remove RegCure from Add/Remove programs in Control Panel then exit the program
click the start button, then Run and in the dialog box, type "msconfig" (without the qoute) and press ok
in the System Configuration Utility window, select the startup tab
uncheck the box with the RegCure entry then click apply and ok, then choose 'exit without restart'
download and install this (Absulutely) free utility >>> http://www.ccleaner.com/
first run Cleaner (click the cleaner button / analyze / run cleaner
second Registry (click Registry button/ scan for issues / fix selected issue
no need to back-up changes just select fix selected issues
when done restart your computer
when a message box appear regarding the system configuration, just click on the box which says 'do not show this message again and click OK
hope this solves your problem
if problem persists see me in YM cpenny29@yahoo.com
Oct 24, 2008 | Microsoft Windows XP Home Edition
Dell CPU fan inside went out
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
May 08, 2008 | Dell Dimension 4600 PC Desktop
First of all check that you using the administrator account to install and uninstall programs.
you probably changed your permission to Program Files directory.
Nov 08, 2007 | Microsoft Windows XP Home Edition
Intel Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
