Question about iLO 2600 Television
My ilo says hd tv right on it, but i cant hook up hdmi cords to it
  • 668 Answers
It may say HD on it but it may be a HD READY set, not a full HD FORMAT.
If it has componet inputs on it,( green, red, blue, and two audio inputs), you can use
them and still recieve HD. If it does not have componet or HDMI inputs on it , it is not a HD set
at all.
Hope this helps,
Skyassoc
Posted on Jun 16, 2009
Philips 20pf5120/28 Calibration for gaming using DVI Input
lololol HD to standard video - standard video back to HD is going to cause some issues. Go straight HD to HD with a hdmi to dvi instead. Even if your tv cant do HD theres a loss of information and signal for every adapter you put in and the length of the cord.
Dec 25, 2014 | Philips Televison & Video
I have an ILO - 32HD Television but the cable cord that comes from the wall does not have a place on the TV to connect to. There is an indentation labeled ANT in the shape of a USB port which it isn't,...
Your TV comes with HDMI, DVI, Component In and S video in. Since it has no Tuner built in you will have to use a Set Top box with either component out or if you buy an HD Set Top box with HDMI out. The later will be in your favor so that you can use the only component video input for your old DVD player and not keep juggling pins at the back
Mar 07, 2011 | iLO 3200 32 in. LCD Television
Trying to hook up my panasonic tc-p50c2 to comcast hd digital cable box and cant get it to work with hdmi cord..nothing is showing
Use only the hdmi cord to hook it up and go to menu on the tv and select hdmi for hook up and you should get a picture. Make sure your cable cord is the only cord running to the cable box , you don't need any other cord.
Feb 09, 2011 | Panasonic TCP50C2 50 in. TV
I'm trying to hook my hp laptop to my hd ilo tv via hdmi cord but my tv keeps saying no signal
you have to tell your laptop to do either a dual screen or use the external screen (TV) instead of the built in one. If your using a Windows based computerit will be located in the control panel to change this setting
Dec 03, 2010 | Televison & Video
I bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
How do i hook up my ILO TV to direct TV satelite?
i have a ilo 32 in hdmi hdtv and i have mine hook up to direct tv .on the back of the receiver plug your red,white and yellow into the audio 1 of the direct receiver. on the back of your ilo tv plug the other end to the av1 and use S-VIDEO ALSO. plug the sat cord to the ant.in. on the tv set remote hit video and go down to s-video and hit ok. you need to plug all three plugs into their color ans the s-video too in the AUDIO section. mine works great !
Dec 30, 2008 | iLO 3200 32 in. LCD Television
32 ilo lcd
most boxes have component out or HDMI connection use either one and cable box or satelite came with instruccion on how to connect it ..
Mar 30, 2008 | iLO LCT32HA36 Television
ILO 26" LCD HDMI TV
I had the same problem at first. Then I went back to fry's and bought a new DVI cable. Make sure you bought the right one.
Nov 25, 2007 | iLO 2600 Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Televison & Video Logo
124 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
