Hi, i can't get access to my router. It tried
Hi, i can't get access to my router. It tried to find ot my default router via Start>Run>cdm>ipconfig. But it has not help. Via the numer of default router, i have got via these commands, i could not get access to the router.
  • togulew Jun 17, 2009
    Thanks. I'll try it
  • 555 Answers
Hello my friend, you can check you network connection configuration and u can view your router property and its ip address. Make sure that you have inputed the correct ip address on your gateway to access your router. Also you can reset you router in order to load its default configuration. Additional tips if all of necessary steps you have already tried then try to reconfigure again your router.
Posted on Jun 17, 2009
Browser wont access http://192.168.1.1/
Confirm that you are connected to the router via a ethernet cable, unless you specifically configured wireless management within the router.
Confirm that you are being assigned an ip on the computer you are trying to configure from. (At a cmd prompt type "ipconfig". You should have an address 192.168.1.x if in fact 192.168.1.1 is your default gateway. Also if this router was configured for secure only management you will need to connect via https://192.168.1.1
Dec 08, 2011 | Zyxel Prestige 660HW Wireless Router...
Tip
Cannot access 192.168.1.1 page of a router
If you are trying to get into the router page and you cannnot access it.
Most routers uses 192.168.1.1 but some uses different address so make sure to follow the steps below just to make sure that you are typing the correct number.
1. Check first your computers default gateway.
Click start
RUn
On the run box type CMD.
It will open the command prompt or the DOS prompt.
On the blinking cursor, type "ipconfig"
Then press enter. take note of the default gateway.
2. Once you g ot the default gateway. Open your internet browser and enter the default gateway numbe ron the address bar, and then press enter.
on Jul 04, 2010 | Computers & Internet
Tip
Hi, I want to use the LINSYS Router as an alternate wireless acces point. I´ve...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Feb 20, 2009 | NetGear DG834G Router
I need to access the d link configuration page. while keeping the internet connected to the router i am plugging a cable to the laptop and to the router and entering 192.168.0.1 an error message is...
Hi tkoleilat
If you want to access the router configuration page, follow the steps mentioned below:
If your IP starts with 192.168.X.X or 198.162.X.X then open internet explorer( http address box) and type 192.168.1.1 or 198.162.1.1 and it will prompt for User ID and password
Default User ID " Admin" or " Administrator"
Default Password " password " or " admin "
This will help you to access router page.
Note: To perform these steps you need to be connected via Wired LAN cable to Laptop and the main internet cable to be connected to router.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | D-Link DIR-600 Router
Router working as Access Point, unable to access via we browser
Please try first plug out the router and plug in again then press & hold the reset button till the power led become red and release. If that doesn't work, plug out the router, pressing and holding the reset button plug in the router.
Let me know the result please.
Thanks for joining Fixya.
Have a good day.
Feb 22, 2010 | Dynex Wireless-G Broadband Router
Cannot connect to internet via wireless router
You better reset it to the factory settings and reconfigure
Nov 08, 2009 | NetGear WGR614 Wireless Router
How do I setup security on my belkin wireless router that has been installed already?
First here is the link to download the user manual in case you don't have it:
http://cache-www.belkin.com/support/dl/p74559-g_f5d7230-4v9xxx_manual.pdf
Now when talking about security, it depends on which part you want to secure:
1- secure the access to the router web interface: you can change the default password. the default password is blank so there is no password which is not secure at all.
2. secure the wireless access: you can change the WEP or WPA key used, first you will need to access to the router web interface and go to wireless security and then change the key. an other option is to filter by MAC address, so only the MAC addresses put in the list will be able to connect via wifi.
3. secure the incoming traffic: the NAT is enabled by default in all routers, but you can also add some rules for the incoming traffic.
That's very much it when talking about security of a wireless router.
If you need help to secure your router, i can work with you directly on your router and do the job via a remote control software like teamviewer.
Best Regards,
Oct 29, 2009 | Belkin (F5D7230-4) Router (587009)
Can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
Hot to use LINKSYS Router as an alternate wireless acces point
this is not a wireless repeater i do beleive this is what want. You need a router or gateway with this function. look at this product http://www.linksysbycisco.com/US/en/products/WGA600N
Feb 20, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot log on to dwl2000ap
If the SSID changed to the default then you know that the router reset to the default settings and you should set your computer to automatically get its IP address via DHCP. I always set up my routers through a Wired connection first, just to setup the router and then go with the wireless. The default for the router should be 192.168.0.1 and subnet 255.255.255.0 . If the computer is set with a static IP address, change it to obtain an IP address automatically or the network card will not bother even looking for an address.
Aug 17, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Computers & Internet Logo
261 people viewed this question
Alun Cox
David Payne
David Payne
