SOURCE: Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
SOURCE: My ACer T180 does not boot boot up
sound like the hard drive. do you hear the drive spinning?? you may need replace or reformat.
what OS are you running....?
SOURCE: trying to start up an acer aspire T180
can you tap F8 while it is booting and start in safemode or select boot with last good know configuration?
SOURCE: pc doesn't boot stops at set up
Your computer is having some problems at POST. Try removing one of the memory dimms you have installed. In case you have one leave it like that and remove Hard Drives, optical drives, any usb devices on the back and try again. In case it boots start attaching the hard drive and try again.. if it boots, add the optical drive and so on until you get the failure.
I hope this helps.
