Question about Cameras
I have a Minolta Rokkor-x 200mm telephoto lens with fungus
I have a Minolta Rokkor-x 200mm telephoto lens with what looks like fungus inside. It's white and appears to be cloudy spots along one of the inner rings as you look through the far end or ouside of the barrel and look in. I heard the mildew leaves permanent damage so I don't know how far gone this is. I never really inspected the lens before and had it a number of years. Is it relatively cheap to have someone clean it or could I do it myself? How much would it cost if I had it done?
-Ridley
    Brigadier General:
  • 3,006 Answers
Lens fungus is really common and it's not cost effective to repair. Even if the fungus is removed then the multicoatings are permanently damaged.
The good news is that until the fungus becomes pretty severe the image quality doesn't suffer much as most photos use the lens stopped down to some extent and this means that if the centre of the lens is clear then there's nothing to block the light paths.
Unfortunately it does tend to spread, so keep affected lenses in a separate camera bag to the rest and if you can afford to do so then throw them away and replace your camera bag as it will be loaded with microscopic spores waiting to attack more lenses. Making sure that your camera and lenses are completely dry and free of condensation before storing them until next used will prevent reoccurence.
Posted on Jun 23, 2009
The lens has spider webs inside
Sounds like fungus/mold. Send it in to Canon or reputable repair shop. It will only get worse.
Jan 25, 2014 | Canon Fd 75-200mm F/4.5 Macro Telephoto...
Fungus in minolta 200mm f2.8
It is necessary to disasembly the unit an clean both optical and mechanical components.
Service job.
Oct 25, 2013 | Minolta Telephoto 200mm f/2.8 APO G Maxxum...
Clean inside lens fungus
Whatever you do, do not open the lens. You will never be able to reassemble it. If the fungus is adversely affecting your images, you need to take it to a qualified camera repair man or send it to a Nikon repair depot found on the Nikon website. If it is not affecting your pictures, I would just live with it.
Oct 05, 2013 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
If you realy have fungus in your zoom lens, you can't do anything. If it does not show on the pictures, just keep the lens dry. (use silica gel) If you want it it be repaired, it will cost more than an new lens.
What size lens do i need for this camera?
You just need any Minolta AF mount lens. Sony Alpha lenses also physically fit as Sony inherited the Minolta lens mount when they bought the company, but as they are a later development not all will be electronically compatible.
The size of the lens depends upon the focal length of the lens and you choose that according to how wide a field of view you desire. Typical lenses are 28 and 35mm wide angles, 50mm "standard" (approximately the same perspective of how the human eyeball sees images), 70 to 90mm short telephoto lenses (a narrower perspective and very good for portraits) and higher numbers are narrower perspective telephoto lenses for viewing increasingly distant objects. In practice, the available lenses will be incorporated into zoom lenses which incorporate a seamless range of focal lengths within one single model. The word "zoom" reflects the fact that you can seamlessly change from say 28mm wide angle through to 80mm short telephoto and every single setting between them
Any zoom which starts at less than 50mm and finishes in the short telephoto range is called a standard zoom and is the lens that most autofocus cameras were supplied with. The next most common size will be something like a 70-200mm which is a telephoto zoom (or tele zoom) and takes you from a portrait lens to a genuine 5x magnification telephoto. You may also find so-called "super zooms" which do the whole job on one, for example 28-200mm. but the more jobs a single lens tries to do, the bigger and bulkier it becomes and the image quality deteriorates due to poorer contrast and greater image distortion at each end of the zoom range.
This is not an exhaustive answer, as there are entire books on the subject, but hopefully it's been of help to you.
Please take a moment to rate my answer or to add a comment if my answer has left you with unanswered questions which need to be resolved before you can rate my reply.
Feb 18, 2011 | Minolta Maxxum 400si 35mm SLR Camera
What size lens fits a Minolta Maxxum 3xi??
It depends entirely upon what you're after and the type of photography you wish to undertake.
Any Minolta AF mount lens will fit. 28mm is a standard wide angle, 50mm is a standard lens with a field of view approximately the same as the human eye, 80mm is a slight telephoto and for distant subjects 200mm is a long telephoto. Some lenses combine a few into one, they're called zoom lenses and will typically be something like 35-70mm, or 70-200mm. The measurements relate to the focal length of the lens, but generally the larger the number the longer the lens sticks out at the front. Zoom lenses are bulkier and heavier than fixed focal length lenses, but they're also the most commonly used types these days.
Sep 03, 2010 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
POSSIBLE MOLD INSIDE CAMERA LENS
It is lens fungus and you're correct in your assumption that it's uneconomical to professionally repair on your lenses. But it need to be pretty bad before it affects image quality so don't junk them just yet.
Some types of lens fungus can be killed simply by leaving the lens out in sunlight, but I'd suggest that it's better to leave them exposed to the indirect sunlight on a bright overcast day to prevent any chance of sharply focussed light burning the inside of the lens. Killing the fungus won't remove the dead stuff but it prevents the problem getting worse.
May 29, 2010 | Quantaray 100-300mm F4.5-6.7 Zoom Lens for...
My problem is fungus growth inside the lens. Is there a service centre that deals with this problem ? Olympus 90 mm Macro
i have got the same problem my friend and i have just recieved an email telling me to put lens in my camera bag with 2 packs of Silicone gel and the fungus will be taken care of ,if this is not interfering with pics dont be to concerned.
Oct 30, 2009 | Olympus Telephoto Zuiko Macro 90mm f/2.0...
Clean fungus rear lens
Oh This Could be a problem. But try just wiping it with a lens cleaning kit. If that dosnt work take it to a camera shop and let them work on it.
Aug 28, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Cameras Logo
414 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
