Question about Northern Industrial 2 Hp Twin Tank Electric Air Compressor
COMPRESSOR ONLY GOES UP TO 65 LBS.
MY TWIN TANK husk air compressor WILL ONLY PUMP UP TO 65 LBS. HOW CAN I ADJUST THIS?
    Habit-Forming:
  • 174 Answers
This unit should have a pressure switch that cuts the unit off and on with a adjustment to set the cut out .most switches have two adjustment screws.one of them tells the unit to kick on when the pressure is getting low.the other adjustment will raise the pressure to the desired amount.
Posted on Jun 18, 2009
Bosch CTE4 -20w compressor after releasing all pressure on tank it worn't restart?
pressure cut out switch could be bad or out of adjustment or bent. Find owners manual go to adjustments and follow instrctions for cut out switch adjustment.
Apr 15, 2013 | Bosch CET4-20W Wheeled Twin Angled Tank...
Husky model WL6605-00AJ,will pump up to 65psi,thats all the air showing on thr gauge.The compressor is still running
You Might Have Water Condensation Inside The Tank Therefore It Can Only Fit So Much Air Into The Tank Which Is Why Its Always Better To Completely Drain All The Air Out Of The Tank When Not In Use.
Mar 17, 2012 | Air Tools & Compressors
Tank pressure goes up to 40 lbs only and motor will not shut off
Hi, my name is John. Welcome to FixYa. You have air leaks. Check all lines, pressure switch, line coming from pump to tank. You may have to remove this one to inspect it. Check valve at the bottom of tank. Thanks for choosing FixYa....John
Nov 27, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
MY COMPRESSOR ONLY PUMPS UP TO ABOUT 65 LBS. CAN IT BE ADJUSTED TO HIGHER POUNDAGE?
yes most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle back on.
Jun 16, 2009 | Air Tools & Compressors
Not pumping up to capacity, motor and compressor working fine,
If your pump is shutting off before it reaches it's max psi. then you need to adjust you switch. Under the black case there are two adjustment screws. One is the high\low adjustment, the other is high pressure cut off.
The first will change when the pump turns on and off for your low psi setting and the high setting simultaneously.
The second will allow you to raise or lower just the high setting. There should be a diagram under the black cap to show which is which. Adjust the high side only and just a 1\4 turn then run the compressor and see if that takes care of the high setting.
May 29, 2009 | Northern Industrial 2 Hp Twin Tank...
Does not put enough air in tank
You either have a faulty or out of adjustment regulator.
Mike
Jan 06, 2009 | Campbell Hausfeld 28 - Gallon Air...
Twin tank air compressor does not pressurize past 65 to 80 psi.
machine inlet valve not sealing in cylinder head valves need to be removed for assesment
Dec 03, 2008 | Northern Industrial 2 Hp Twin Tank...
Northern Industrial 2 Hp Twin Tank Electric Air Compressor Logo
229 people viewed this question
Top Northern Industrial Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Northern Industrial Air Tool and Compressor Expert? Answer questions, earn points and help others
