The tv is stuck on one channel. none of the buttons on the tv or the remote work! what do i do?
    Genius:
  • 1,341 Answers
First thing I would suggest is to try to put new batteries,then if that does not work the cheapest way out is to get a universal remote and use it.It cost 0.99pence in the uk or try on ebay.
Posted on Jun 16, 2009
I have a Soniq E55Z11a TV and we did an auto search for channels. It is stuck on Installation Guide screen as no remote.
Does switching it off and back on at the wall help?
Page 13 of the manual shows the button functions (I'm sure you know). The alternative is to buy a dedicated remote from some seller like ebay.
SONIQ E55Z11A AU Instruction Manual Page 13
REPLACEMENT SONIQ REMOTE CONTROL QT141 E46Z10A E46Z11A E55Z11A E55Z11A AU...
Jul 26, 2016 | Televison & Video
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
Tv stuck on one channel
It sonds that the main system control memory IC is faulty. Replace it. It will look somewhat like this.9302adbd-7193-43b4-ad70-ab4cde7dc3d3.jpg
02d1bdcc-d88f-465e-b843-9006f4b10c79.jpg04fd848f-72f2-43bf-b9ed-af896ad213a2.jpgFor more details http://electronicshelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 27, 2013 | Insignia Televison & Video
The tv is stuck on a game channel and none of the buttons work such as the channel page, menu, select, guide, etc. I have replaced the batteries
Good day!
may I know if your remote is original or universal remote.
If your remote is universal you have set-up the remote code.Because universal remote is need to set-up every time it loose the battery or power.
If your remote is original and the battery is new.You have to do is replaced the IR sensor of your remote.
Thank you
May 28, 2011 | Hughes HRMC9 Remote Control
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
regards
3rq8 (Triarcuate)
Jul 25, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
Universal remote locked out TV
I was able to get back to using the TV after several frustrating tries at finding the right combination of searches and pressing buttons. The function I was able access was not a function I could get to with the remote suppilied with the TV. And once stuck in this mode nothing would clear it Turns out that the power button gave me channel 8 and the #1 button gave me this display calibration? function. Obviously not using the right code. Never the less all is well with the TV and I got my VCR working with the $2.99 remote and I will attempt the other units TV and Magnasonic DVD later when I have regained my composure.
Nov 29, 2008 | Universal Televison & Video
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
