Question about Heavy Duty 648967 Arrow Electric Staple Gun/brad Nailer
Will an electric stapler cause glitches on a PC nearby on the same power line
  • 867 Answers
The heavy draw of current by the stapler is causing this. use a different line with an extension cord, short and thick as possible. nothing is wrong, this is normal.
Posted on Jun 16, 2009
WHAT DOES F1 CODE MEAN.
The F1 error code on this model of Frigidaire range indicates that the electronic oven control board detects one of the following errors: Failed oven temperature sensor probe. Shorted keypad. Internal electronic control board error caused by a power glitch or surge through the electrical lines
Dec 01, 2017 | Kitchen Ranges
Been using stapler for past hour suddenley trigger
Could be a bad power cord: broken wire at the switch; a bad switch; the stapler needs lubrication; or the stapler is shot.
Jun 19, 2014 | Stanley Tools TRE550 Electric Staple/Brad...
What does F01 code mean?
The F01 error code indicates a failed primary electronic machine control board. This can be caused by a glitch or power surge through the power lines. Try unplugging the dryer for 5 minutes and see if the code clears. If it doesn't, then you will have to replace the electronic machine control board,
Dec 17, 2013 | Kenmore Elite HE4 Electric Dryer
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
How do I load brads into my chicago electric
I'm looking for the same thing, cause they seem to big
Mar 02, 2013 | chicago electric power tools 3-In-1...
Sears microwave m/n 721.63663300, displays F9 code ,what does that indicate?
The F9 error code indicates an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Dec 23, 2011 | Microwave Ovens
Apple cinema flickers when warmed up
  1. Adjust the brightness setting. The brightness control (marked by ) is under the right front edge of the display.
  2. Calibrate the monitor using the Calibrate option in the Monitors control panel.
  3. The flickering could be caused by interference from a nearby power line, a fluorescent light, or an electrical device for example, a radio, a microwave oven, or another computer. Try relocating nearby electrical devices, or moving your computer and display.
If you are still having problems with your Apple Cinema Display, please consult Apple support here:
https://expresslane.apple.com/GetproductgroupList.do?PRKEYS=PL117
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 23, 2011 | Apple Cinema HD Display30" Flat Panel...
I have a Tenma 72-7245 DC Power Supply. When the line input power is interrupted momentarily (power glitch), the power supply does not reset and resume operation. Is there a way to change this behavior...
It is probably a 'switch mode' power supply and the glitch is causing the oscillator to hang. Other than a re-design of the circuit, I don't see a fix for the problem. You might look into a 'linear' power supply which doesn't have this difficulty. Hope this helps!
Nov 24, 2010 | Garden
My Swingline Stapler Model 51110 electric stapler no longer staples. The staples will not move forward and it just does "blank" stapling. Also, it goes off on it's own all the time running stapples...
I have the same issue; however, there is some resinous material that came out of it as a result of my trying to figure out why it wasn't stapling anymore. Anyone know where I can take it for repair?
Aug 05, 2010 | Office Equipment & Supplies
No oven no burner
The F13 indicates a problem with the EOC (Electronic Oven Control board). This can be caused by a power surge or glitch through the electrical supply lines. You can try disconnecting electrical power completely from the range by unplugging it. Leave it unplugged for a few minutes. If the fault code returns when you plug the range back in, then the EOC will need to be replaced.
Dec 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Heavy Duty 648967 Arrow  Electric Staple Gun/brad Nailer Logo
60 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Paul Carew
Joseph Hoffmann
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
