Question about i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case
Unrecognized hard drive
I have a maxtor diamondmax +9 hard drive in an irocks external enclosure that i am trying to use as a back up. when i go to MY COMPUTER it recognizes that something is there and calls it j. but when i go to PROPERTIES it has no info. all it says is the file type is RAW and shows the drive as full. when i go to DEVICE MANAGER it does not even recognize it at all. what are my options ? THANKS jn
  • 2 more comments
  • jmnme Jun 17, 2009
    hi nina, i have windows xp home. i have also contacted tech support at maxtor and was told by them that the problem was probably with the i-rocks enclosure. i was unable to get any info from i-rocks but the enclosure has never been used before. i'm not sure about the drive. i dont think it has been used either. thanks, jn
  • jmnme Jun 18, 2009
    i am looking for the disc now. will let you know if i can find it. jn
  • NinaE May 11, 2010
    Have you tried reinstalling the driver for the external drive ???
    What operating system do you have (i.e. Windows XP, Vista ...) ??
4 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: dropped hard drive
You can try using Ghost to back the data up. It sounds to me like a head crash.
Posted on Jun 14, 2008
bob_computer
  • 3153 Answers
SOURCE: my irocks enclosure only came with 98 drivers
Xp does not need them but check the information below before you panic.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Aug 30, 2009
  • 118 Answers
SOURCE: How do I delete all
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Posted on Jan 14, 2011
Maxtor diamondmax plus 9 hard drive not seen by computer
I'd say you did a good job troubleshooting. Replace the drive.
Dec 29, 2012 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Install internal hdd into external enclosure
yes you can... needs to be the right type i.e. SATA or EIDE that matches your enclosure and (USB) interface board...
Feb 25, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Windows Xp Setup Problem : "setup cannot access the disk". I have HDD: Maxtor Diamondmax Plus 9 80GB ATA/133 HDD.
try doing a F disk on the hard drive first then format it and make it the active drive and then try installing the xp software. if it has had another operating system say for instance windows ME it will not install on that drive without removing it. You can also go to www.maxtor.com and download their free hard drive tools to see if there is a problem that thier software can fix. the software is for free.
Jan 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
When i start my computer my drive (maxtor diamondmax plus 9) freezes and starts makeing a knocking voice...? do i have to get a new 1? or this can be fixed
it sounds like hardrive as dropped a disk you could try a prog called hardrive regenerator of the net if i was you i would get a new hardrive i have trouble with maxtor drives , seagate or western digital seem better drives to use
May 17, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Can I use my maxtor diamondmax +9 as an external harddrive
Yes, this is very possible. All you need to do is purchase a harddrive enclosure. This google link contains shopping results for this item--> http://www.google.com/products?rlz=1C1GGLS_enUS291US303&sourceid=chrome&q=harddrive+enclosures&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
I hope this helps. Let me know if you have any questions.
Thanks, Raph30
Jan 27, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Maxtor 120GB Hard Drive
Is that external???
Mar 24, 2008 | Maxtor Hard Drive
i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case Logo
420 people viewed this question
Top i-rocks Computers & Internet Experts
micky dee
Alan Rothery
Krishna Raju
Are you an i-rocks Computer and Internet Expert? Answer questions, earn points and help others
