Question about Frigidaire ATF6000ES Front Load Washer
"Pau" error message on the ATFB7000ES
I opened the door while it was already washing a load, to put one more item in the load. I did this and walked away. Later that evening I checked on the washer and the display says "PAU" then "ERR". I pressed cancel numerous times and tried to reset the machine but nothing worked. I was told that if you press the cancel button and the start button simultaneously for 3 seconds, it would reset the machine; unfortunately, this did not work either.
Do you have any suggestions on how I might fix this?
Thanks,
JP & JV
    Problem Solver:
  • 19 Answers
Take out the plug for 5 min
Posted on Nov 01, 2007
Machine stops and PAV appears on the panel
Thank you for your post, campy chaney!
I understand that your Frigidaire washer is displaying an error code of "PAV". "PAV" is not a valid error code, your washer maybe displaying a "PAU" error code. It could be a possible issue with a low light on your LED panel. If it is a "PAU" code that could be an interruption within your cycle. I would suggest performing a reset on your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. When you restore power to your washer and continue receiving the "PAU" code I would suggest having a professional technician out. This could be a possible problem with your control panel, door latch, or door strike. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 06, 2015 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire front load washer #ATF6000SF1 and need to reset the PAU and E41 error code. I cannot get the unit into diagnostic mode to accomplish this. How can I reset this code?
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
Dec 07, 2014 | Frigidaire Washing Machines
Pau 12 flashing frigidaire
Hey friend, thanks for your inquiry!
I see off your post your Frigidaire washer is showing a "PAU 12" code. Typically "PAU" stands for pause which means the cycle has been interrupted. I would open and close the door to assure that there is a proper connection between the door strike and door latch. If you check that and still receive the "PAU" I would recommend a reset, which can be done by flipping the household circuit breaker off for roughly ten minutes. Hopefully this is helpful. -Matt
Aug 07, 2014 | Frigidaire Washing Machines
Frigidaire front loading washer will not start will not stat, I get a PAU or ERR message, tried resetting by unplugging for an hour, removed and cleaned soap dispenser, and checked door for proper closure....
Thank you for your question, Friend.
If you are still receiving an error code PAU after resetting your washer, then the door of your washer is probably not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, then your washer could possibly have a faulty door latch, door strike or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Best - Z
Aug 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
Code saids pau
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Hi Mr. Barry Coates, I have frigidaire ATF 6700FS front load washer. I am having problem with error code E41 and all time it shows me PAU. I tried all the solution on this site but nothing works. Could...
E41 - Control board thinks the door switch is open.
PAU means PAUSE in the cycle; if you are try all methods, I assume that the control panel needs to be replaced.
Check in this link your Control Board Replacement
Hope helps.
Oct 12, 2011 | Frigidaire ATF6700FS Front Load Washer
Frigidaire ATF6000FS1 Error Message E41. I set up the machine, hit the start button, and I only get he PAU note across the screen. The washer will not start up. Ran the Diagnosis and come up with E41. ...
Hello
The circut board thinks the door switch is open.Try unpluging machine for 3 min.The restart as normal.
Its more a control board issue then a door switch.
Apr 08, 2011 | Frigidaire Washing Machines
I am getting a PAU code and it will not let me continue.
Possible cause: inlet valve, pressure switch or control board failure.
Possible solution: Do not open door, select drain/spin to remove water, restart cycle.
May 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
317 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
