Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
My dehumidifier runs all the time but is always empty and it's brand new. serial # NRF1CSB1016. I have it set on fan speed low desired humidity dry.
  • bozcro
    bozcro May 11, 2010
    seems like the comprresor is not working, do you hear it kicking in? (same as an airconditioner or fridge motor sound)
SOURCE: 20% humidity reading
Hi, I just cleaned my dehumidifier and had the same problem as you. I used a spray water bottle and was not aware that the humidity sensor was being soaked. Very stupid of me!! Luckily I have two same dehumidifiers and used the other sensor to replace the one that I so stupidly ruined, and behold my machine worked again. Now I have to buy another sensor. To make sure we are talking about the same thing, my sensor is white,about 1 inch by 1/2 of an inch. It as 4 wires connected to it. To access it you remove the water tank, you will see 2 screws. Remove those, and pry the front panel loose. Be careful the top of the panel is held by two plastic hooks, they break easy. The sensor is located on the right side just above the radiator, under a produting oval lip which as foam around its rim. The wire colors are red black blue and yellow. Good luck Herman
Posted on Sep 20, 2007
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
SOURCE: fan runs all the time
What control did you replace? My fan runs all the time as well. The unit appears to be working as the bucket is filling with water. However, the fan never stops running (which is driving up my eletrical bill)...
Posted on Jun 04, 2008
SOURCE: Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Posted on Jun 05, 2008
22yooper
  • 828 Answers
SOURCE: 2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Posted on Jun 29, 2008
How do I get my Danby dehumidifier, model#DDR70A2GP stop its fan from running continuously once it reaches a desired humidity level? Thanks
I just read your instruction manual for you, and it appears that you can't. You choose the humidity setting and you choose your fan speed and that's it. The machine will stop when the bucket is full.
Your manual is here;
http://www.danby.com/cms/documents/pdfs/en/DDR50A2GP_DDR60A2GP_DDR70A2GP_DDR60A1CP_EFOM_%28DM%29_Revised_Feb_27_2013_%28web2%29.pdf
Sep 12, 2015 | Danby Dehumidifiers
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
I cant change humidity levels
Hi Ra Ma,
After you have set the desired humidity, the readout will display the actual room humidity. It has a built in hygrometer which will be on the display while it is running.
You change it and it shows the actual levels.
See page 5 on manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Mar 02, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
Does the Fan on a Haier HD456E always run,
I believe the fan is designed to run all the time, and no, it costs very little to run an 18w fan. You can use a timed socket, or switch it on and off when needed. I don't believe the Haier has specific switching times.
Apr 16, 2012 | Haier HD456 Dehumidifier
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
Dehumidifier runs from low to high.does not keep same fan speed.
If you are operating the dehumidifier in continual mode, this is normal, based on the humidity extraction level you have the unit set on. It senses when there is humidity to remove and speeds up. When it has reached the level you have set it for, it slows down and keeps the air circulating, until it senses a need to speed up, again.
Hope this helps you. Thanks for choosing FixYa.
Jul 28, 2011 | Maytag M7DH45B2A Dehumidifier
When the mode button is pushed, I only receive the option of dehumidifying, or just fan. The manual claims it has a heat option but it is not available. A friend of mine has the same one and they have the...
Sorry to read about your problem, I hope this helps you out.
Their has to be a model difference issue . I have checked the Manuel and have put a copy of the section, for modes. and their is no heat only mode.
Your unit uses heat anyway, so i really do not know how, heat only would help you. I would say to look at the sticker on your friends model, and see if the numbers are exact.
Default Setting:
When the unit is first connected to a power supply, the electronic circuit board will automatically default to the following factory settings;
Mode: Dehumidifier Humidity Set Air Value:60% RH Fan Speed: = Low
NOTE: In the event of a power failure or the unit is switched 'Off', the most recent settings are retained and restored once the power is switched "On"/resumed.
IMPORTANT NOTE: Depending on the ambient humidity conditions, when power is restored or switched 'On' the dehumidifier may not start automatically under the factory or custom (see page 7) default setting. This is an indica- tion that the ambient RH% level of the surrounding envi- ronment is lower than the current default setting and it may be necessary to select a lower set RH% value.
DRY MODE SELECTION: 1. The unit does not have to be switched on (opera- tional) to select/set a program. All programs can be selected with the unit in the "off" position.
2. Press the MODE button until the Dry symbol is shown in the mode area of the display. Note: Each time the MODE button is pressed, the setting will alternate between DRY (dehumidifier) and FAN (only) mode.
3. Press the or cursor buttons to select the desired RH% operating value. To select CONTINUOUS operation,pressthe buttonuntilthesymbol"--" appears in the SET AIR display. During CONTINUOUS mode operation, the humidistat (control) will be by-passed and the compressor will operate non-stop regardless of humidity conditions.
FAN SPEED SELECTION:
4. Press the fan symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options. The fan speed you select will appear in the LED display; either a 4 blade fan symbol for 'high fan' or a 3 blade fan symbol for 'low fan' will be shown in the display area.
5. When all settings are complete, press the I/O button to start the selected operation (MODE) and the blue opera- tion light will illuminate.
FAN ONLY MODE SELECTION:
1. Press the MODE button until the fan blade symbol is shown in the mode area of the display. 2. Press the "Fan" symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options.
3. When all settings are complete, press the on/off button to start fan mode operation and the blue operation light will illuminate.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Danby DDR586R Dehumidifier
My dehumidifier is frozen solid
Unplug it ... let it defrost.
Set it to a higher % humidity and make sure the fan is on its fastest speed. If you can set it not run continually (a selection option), do that. Also, set a small fan close by to move more air around the machine. If you have the option, put a hose on the collection device to drain to a sewer.
As your space starts to dry out, set the humidity setting to a lower number. This may take a week or more.
I believe perfect humidity is slightly above 50% - no need to try to get to 40% except in unusual circumstances. If that is the case, get a second device. Or, if your space is large, you may want to add a second device.
I hope this info helps you and your problem is solved.
thanks for using Fixya.com
a
Oct 25, 2009 | Danby DDR556RH Dehumidifier
LG LD65E humidity variance
Is the compressor running or is it just the fan? If its just the fan it is because it is cycling the air and it uses that air flow to check the humidity in the air. If the fan runs non-stop and the compressor does not turn on or the fan does not shut off there is a problem with this unit and you will need to replace it. Since it is brand new you should still be able to return it to the store.
Jun 27, 2008 | LG LD65EL Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
531 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
