Question about Phil & Teds E3 Jogger
Cant seem to get the front wheel to stay on swivel
Keep trying but cant seem to get the front wheel to stay in swivel mode..when you start to move the pin clicks back in place and the wheel stays fixed. would be nice to swivel rather than tip the buggy up to turn corners..i have the phil and ted classic..please help!
I have the same stroller, and it's driving me nuts!
I saw this on a different post:
Solution #2 posted on Mar 04, 2009 cant seem to get the front wheel to stay on swivel - 4%20ratings_thumbs.gif
noavatar_s.gif sausagegirly
Rank: Apprentice
Rating: 100%, 1 votes
hi we had the same problem with our p&t sports buggy, brand new out of the box the front wheel kept locking, driving me mad! we contacted our supplier, kiddicare.com, who were extremely helpful and sent out a "front wheel swivel/fixed catch (screw fixing)" - it has WORKED WONDERS! the buggy is now smooth and easy to handle. you have to remove the old catch pin which can be a bit of a fiddle (when we got the old pin out it was a rivet fixing and very rusty) but only took us 10 minutes. highly recommended if you can get hold of one of these new screw fix pins, which have obviously been brought out to fix a common fault which p&t can't be bothered to recall lots of buggies and fix themselves...... ;)"
I've made contact with the store I've bought my e3 from, now, waiting to hear from them about this 'fix screw'. hopefully it'll solve our probs!
Good luck
Posted on Jun 22, 2009
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
Loola up front wheel not swiveling
The swivel mechanism on the Loola Up front wheels is controlled by a wire which runs up inside the chassis. If your wheel is locked and you're unable to move the swivel button it would indicate this wire has come off its fixings inside. To repair this, we would need the chassis to be sent to our engineers for inspection / repair work.
If you're in the UK and it is under 2 years old please contact your retailer with proof of purchase and they will make arrangements for this under warranty terms and conditions.
If you're in the UK and it is over 2 years old or you no longer have proof of purchase please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 (Excluding Bank Holidays) to book in for chargeable inspection / repair. Charges start at 39.99GBP for single repair and do include courier collection and delivery.
If you're not in the UK please visit www.maxi-cosi.com or www.bebeconfort.com (depending on the make of your Loola Up) and select the country you're in, then use the Contact Us tab to get in touch with the customer service department in your country
Nov 25, 2012 | Baby Gear
Hello i have the bebe car multipla at (vogue color) its says underneat the seat 2005..i am wondering if the wheels can swivel more then thez do thez just seem to go a lill ways ,,has this was bough second...
Whereas the Multipla chassis had front wheels that could swivel by 360 degrees, the Multipla AT had steerable front wheels designed to turn in parallel with each other, by several degrees in either direction, when set in 'steering' mode, or to remain fixed, when in 'fixed' mode, the mode being controlled by a plastic button on the side arm. A set of instructions relevant to your particular model is available from service@bebecar.co.uk.
May 29, 2011 | Bebecar Raider AT Stroller
Does the steering wheel control the wheels? Are the front wheels supposed swivel or stay in one direction?
theres no problem no the wheels arnt turned with steering wheel and the front wheels are supposed to swivel hope this helps if yes please giv thumbs up thanks
Mar 06, 2011 | Little Tikes Cozy Coupe
I have a jane slalom pro my front wheel is driving me mad it is wobbling so much that my pram will not move forward sometimes, any help would be appreciated.
We have this problem with our powertwin when my toddler is not riding in the front and I only have the baby in the carseat at the back. There is not enough weight at the front to keep the front wheel firm on the ground. I solve the problem by switching the front wheel from swivel mode into locked mode whenever I only have the baby in the pushchair. But I switch it back as soon as my toddler gets in the front since its impossible to navigate with a fixed front wheel when the pushchair is fully loaded.
Nov 21, 2010 | Jane Powertwin Azulon Stroller
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Babyjogger city elite front wheel shakes
You need to put more weight on the front of the stroller. The wheel is shaking because it's able to swivel....
Apr 12, 2010 | Baby Jogger City Series Single Stroller
Phil and Teds Vibe front wheel doesn't swivel
I had this problem 4 times with mine!!! the company tried to repair (unsuccessful) and then replaced it. The same problem occurrred with the second one after a month. Phil and Ted's took it back and put a thing called "super lube" on it. At first it was no better, but with a little use it seems to have come good.....for now. This is a terrible stroller that I really regret buying!!!!
Nov 19, 2009 | Baby Gear
The front wheels on my Maclaren XLR keep locking up
When you click the wheel release (to make them go onto swivel mode) press a little harder as it sounds like you haven't fully engaged the release mechanism.
I hope this helps.
Oct 07, 2009 | Maclaren Vogue Umbrella Stroller
Front wheels keep getting stuck in swivel postion
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Feb 15, 2009 | Valco Runabout Tri Mode Jogger
Phil & Teds E3 Jogger Logo
759 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
