Question about Orbit Sprinkler System Power Source Transformer #57040
Orbit sprinkler system
I had a Hunter sprinkler system that w working fine. the timer just quit, so I replaced it with a model 27781 Orbit #6 zone timer, and a inch anti sophen master value It's all wired in correctly nothing will work now. I also tired to advance to the next station and it will not change station. What am I doing wrong. Thanks Jerry
    President:
  • 1,723 Answers
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
How to wire
First check the solenoids by performing a continuity test on all of them. For all the solenoids that test good, power each one with 24 volts to make sure that the plunger moves. Then go to the timer and initiate an ON cycle for, say, zone one. Go to the zone 1 connector on timer and check for presence of 24 volts ac. If not present try zone 2 for output. If nada then there is something wrong with the electronics of the timer.
Mar 28, 2015 | Orbit 6 Zone Automatic Irrigation Watering...
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Need operating instructions
Go to Orbits web site and download instructions. Or since you have the least expensive timer known to man simply buy another one for $20.00 then you will have instructions and a spare timer. You will need it trust me.
Jan 23, 2014 | Orbit 6 Zone Automatic Irrigation Watering...
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
One of my zones keeps sprinkling after I shut the timer off
Which timer do you have?
Copy following link for sprinkler timer manuals
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add comment and describe timer in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 20, 2013 | Orbit Sprinkler System Power Source...
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Aug 09, 2012 | Orbit Hardware & Accessories
Hunter pro C will not allow all zones to water.
The fact that you are getting no error message indicates that programming is not right, or there is electrical short between timer and sprinkler solenoid:
With all digital timers, it is important to clear memory before starting, and then double-check there are no conflicts in programming.
Page 22-23 of the manual has quick-check procedure for identifying shorts that would cause problems.
Check outlet with circuit analyzer to check for correct polarity and grounding.
Google search Hunter Pro C manual to download searchable pdf manual
Keep in mind also that digital timers are susceptible to line noise, and power surge. Simple power outage can disable digital timer. There are no replacement parts.
That's why I recommend good old fashion 14-day repeat-cycle mechanical sprinkler timer with fewer features, but replaceable parts.
For example T8845PV with 24Volt ac output
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8845PV
Jul 15, 2012 | Hardware & Accessories
Orbit Model 57896 I can only get 4 stations I seem to have lost two that I did have.
Try removing the battery, unplugging the timer, plugging the timer back in, pushing the reset button (if you can find it) and try reprogramming for all 6 zones. Post again after trying.
Gary
Mar 15, 2011 | Orbit Sprinkler System Power Source...
Orbit Sprinkler System Power Source Transformer #57040 Logo
1,072 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Hippy_dd
Marvin
Marvin
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
