Question about Prima Televison & Video
Power supply for prima model p5017 is gone.where can i find a replacement?
Prima is out of business.there are3 no replacement parts.
Posted on Jun 17, 2009
I can't find a remote for my Prima TV model#XT-2799. Help!!
Universal remote codes for Prima TV are:
1019 0165 0116 0167
Just note these codes, and buy a universal remote control, which have these setup codes in its code list.
If your TV asks for a five digit code, buy one RCA RCR 311STN model remote control. Five digit codes for this remote control, with Prima tV are:
10761, 10783, 10815, 10817
Jun 13, 2012 | Prima CV2011 TV
Our 2 year old Prima TV quit working. The power comes on, then as soon as picture tries to come on, the TV goes off. Called a repair man and is one of the parts for power, but Prima has gone out of...
gerneric should be able to be used as i had to work on a customers old prima and used some generic parts. ill try and find the link for you for the parts
May 14, 2011 | Prima CV2011 TV
32 inch prima lcd tv model lc-32u16 that won't turn on
You probably have some defective filter capacitors in the power supply. The tops of them may be domed instead of flat. Be sure to replace them with same values listed on the originals - slightly higher voltage rating is OK, but no less! Make sure they are rated at 105 degrees C and not 85 degrees.
Apr 02, 2010 | Prima C2012 TV
I have a Prima P5017 TV I need the specs. I need
I have a Prima TV Plasma Model P5017 The TV turn off alone and when I try to turn on the red light change to the blue and five seconds later turn off.
Mar 28, 2010 | Televison & Video
Prima sreen goes red on me is my tube gone
no ur tv must be had loose contact in video board section...or..driver transitor or driver ic may be failed in the vedio board section..if the tube is gone then there will be several horizontal retrace line will be found with red color, and they will not shake.. have a good day..
Feb 25, 2010 | Prima CV2011 TV
Prima lcd tv, model number LC27R25 wont turn on
Most likely there is a problem in the power supply. Sets these days are so full of safety circuits that most any problem will cause one to not come on. Hard to say. Thanks
Oct 21, 2009 | Televison & Video
Prima plasma kept turning off by itself, then made popping noises in the back of tv and then no power at all!
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees.
Sep 17, 2009 | Prima C2012 TV
Prima l080i
Magic smoke GONE!
Seriously, the main power supply has failed, and requires service. You are probably well past the warranty period, but check with the TV's service center - that information should be in the documents that came with the TV.
Jul 07, 2008 | Prima CV2011 TV
Prima combo tv does not come on when the power button is pushed or even with the remote
check the fuse first then, resolder the power supply of your tv.
Jun 20, 2008 | Prima CV1311 TV
Televison & Video Logo
173 people viewed this question
Top Prima Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
