Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Amana Refrigerator Model ABB2222FEQ Control Panel Cover
I have a new control panel to install in my Amana, but I can't decide how to remove the plastic cover. I don't see any screws holding it in place. Any helpful hints would be greatly appreciated.
  • Amana Master
  • 4,655 Answers
Yes, I can help you and send you the service manual also, Thanks, Sea Breeze
Posted on Jun 16, 2009
Replace motherboard for gsh25vgrbcc
Your refrigerator uses the common GE WR55X10942 control board. On most models you can just swap out the control boards. Some models require a few additional steps, you will have to check your serial number to see if that applies to your model (see instruction sheet included with the control board).
First unplug the refrigerator.
On the back of the refrigerator, there is a panel. Remove the screws and the panel cover.
Unplug wires from the old control board (note where the wires go), and plug them into the new control board.
Plug refrigerator back in and test out.
For more detailed instructions, and pictures click the link below.
How to replace WR55X10942 control board
Jan 25, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
The control panel for my Amana oven, model ACS3350AS, turns off mid cycle. How do I know if the panel is fried or it's something else? Is the control panel easy to find and install?
the fitst thing i would do is check the incomig power. make sure you have constant power ad that the range isnt loosing power. if your power is good, then you may have a bad control. go to www.searspartsdirect.com. type in the model and you can view the price for the control
Nov 25, 2011 | Amana ACS3350AS Gas Kitchen Range
I have an Amana ACS3350AS Gas range and the Control panel cover has cracked due to heat.After much searching on the web I found a replacement but I can't seam to find any manuals on how to dismantle it...
hello, this unit should only have screws under the control panel when you open the oven door. some of them have a side screw on each side when you pull out the oven an inch or two. hope this helps
Jun 08, 2011 | Amana ACS3350AS Gas Kitchen Range
Amana washing machine (ALW880QAW). Does not work in spin cycle. Washer works ok in wash cycle, and in draining water, just the new belt is too loose when it switches to spin. It just burns up the belt....
probably the lid switch is faulty,remove screws behind control panel,then pull control panel toward you and lift up and lay back,now remove 2 screws in the lower front panel by the floor and remove the cover,then 2 more screws to remove upper front panel above the lower one,then 2 more screws in front hold the top on then raise top up like a car hood and the lid switch will be under the top cover
Mar 23, 2011 | Amana ALW880WH Top Load Washer
How to remove the controls panel cover. Our 12 yr old microwave suddenly stopped. No power to display or oven. I have been told that there is a fuze behind the display that is replaceable. Trying to get...
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's an Amana, WHirlpool, Kitchenaid, etc., and you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you need to remove the oven from the wall, the the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool here.
You can download GE owner's manuals and installation instructions here.
Apr 15, 2010 | GE JE1390 Microwave Oven
Kenmore refrigerator 26' side-by-side Model 596.52673200
on the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Jun 10, 2008 | Amana ABB1927DE Bottom Freezer...
Amana control panel sparks
your panel shorted out
replace control panel and wire harness is my recommendation
Although depending on age, these two parts are quite costly the panel alone is 272$ retail
if you decide to buy it you can call amana 866-616-2664
to purchase them, or local dealer normally can sell you the parts
but with a major short like that id recommend replace, if you buy parts bring model, serial, and MFG manufacturing number starting PALW
May 02, 2008 | Washing Machines
Maytag mbf2258hew replace jazz board
bug, the jazz board is pretty easy to replace. The light cover will slide off toward the back. Now if you look behind the control panel you will see two slots. Take a flat blade screw driver and push the cover tabs in while pulling down on the cover. The cover will come down. Two slats slide in on the front and will release, disconnect the harnesses and install the new board. Reverse the process. Catriver.
Sep 04, 2007 | Amana AFB2534DE Bottom Freezer French Door...
AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
May 21, 2007 | Amana AEW4530DDS Electric Single Oven
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
582 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
