Question about Air Tools & Compressors
MY COMPRESSOR ONLY PUMPS UP TO ABOUT 65 LBS. CAN IT BE ADJUSTED TO HIGHER POUNDAGE?
    Habit-Forming:
  • 174 Answers
Yes most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle back on.
Posted on Jun 22, 2009
Torque spec's for the fly wheel
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Cars & Trucks
How to pick the right poundage for my recurve bow?
In a recurve bow, the longer your arms the further you pull the bow back and the higher the pulling weight of the bow becomes as you pull it further and further. A starting bow weight is around 25-31 lbs.
Aug 26, 2012 | Betsey Johnson Archery
How do I replace the serpentine belt on a 1999 Kia Sephia?
1.8L Engine
  1. Using a belt tension gauge, measure the drive belt tension and compare with the following specifications:
    1. Alternator belt (new): 86-103 lbs. (383-461 N)
    2. Alternator belt (used): 68-86 lbs. (304-383 N)
    3. A/C compressor and power steering pump belt (new): 110-132 lbs (491-589 N)
    4. A/C compressor and power steering pump belt (used): 95-110 lbs. (422-491 N)
      Fig. Using a tension gauge to measure the alternator belt tension - 1.8L engines (click HERE for zoom)
  2. Using the deflection method, apply moderate pressure (about 22 lbs) halfway between the pulleys, and compare with the following specifications.
    1. Alternator belt (new): 0.31-0.35 in. (8-9mm)
    2. Alternator belt (used): 0.35-0.39 in. (9-10mm)
    3. A/C compressor and power steering pump belt (new): 0.31-0.35 in. (8-9mm)
    4. A/C compressor and power steering pump belt (used): 0.35-0.39 in. (9-10mm)
  3. If the specifications fall outside the ranges given, adjust the belt as follows:
    1. Loosen the alternator mounting bolt and adjusting bolt.
    2. Adjust the alternator to get the specified belt deflection.
    3. Tighten the bolts, then recheck the tension.
      Fig. Adjusting the alternator belt-1.8L engines
Hope helps.
Oct 09, 2011 | 1999 Kia Sephia
How do I replace the serpentine belt?
1.8L Engine
      Fig. Using a tension gauge to measure the alternator belt tension - 1.8L engines (click image for zoom)
Hope helps.
I recently changed the alternador belt on a 2001 chevy metro lsi, afterwards whenever i start the car , there is this rattling noise and when i opened the hood to check , to the left of the alternador...
Water Pump REMOVAL & INSTALLATION Metro
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Air cleaner
    • A/C compressor suction pipe bracket, if equipped
    • Loosen the water pump pulley bolts. Do not remove them at this time
    • Right side lower splash shield
    • A/C compressor drive belt
    • Lower alternator cover plate
    • Water pump/alternator drive belt
    • Crankshaft pulley
    • Water pump pulley
    • Timing belt
    • Dipstick tube
    • Upper alternator bracket from the water pump
    • Water pump and discard the gasket
    To install: Fig. 1: To ensure a tight seal, be sure gasket surfaces are properly prepared - Metro 7922z704.gif
  4. Clean the gasket mating surfaces thoroughly.
  5. Install or connect the following:
    • Water pump with new gasket. Torque the bolts to 115 inch lbs. (13 Nm).
    • New rubber seals
    • Upper alternator adjusting bracket
    • Oil dipstick tube
    • Timing belt
    • Water pump and crankshaft pulleys. Leave the water pump pulley bolts hand-tight
    • Alternator drive belt
    • Lower alternator cover plate. Torque the bolts to 89 inch lbs. (10 Nm).
    • A/C compressor drive belt, if equipped
    • Right side lower splash shield.
    • Torque the water pump pulley bolts to 18 ft. lbs. (24 Nm).
  6. Adjust the water pump drive belt tension and torque the alternator adjustment bolt to 17 ft. lbs. (23 Nm).
  7. Install or connect the following:
    • Air cleaner
  8. Refill the cooling system.
  9. Start the engine and check for leaks, repair if necessary.
Prizm 1.6L ENGINE
  2. Drain the engine coolant.
    • Negative battery cable and properly support the engine
    • Right side engine mount and support
    • Upper and middle timing belt covers
  4. If equipped with power steering remove the following components:
    • Front transmission mount
    • Radiator fan motor
    • Coolant reservoir
    • Upper radiator hose
  5. Remove or disconnect the following:
    • Crankshaft Position (CKP) sensor electrical connector from the dipstick tube
    • Dipstick tube
    • Engine Coolant Temperature (ECT) sending unit
    • Coolant inlet pipe
    • Water pump and discard the O-ring Fig. 2: Remove the coolant inlet pipe from the block, then the pump - Prizm 7922z705.gif
    To install:
  6. Install or connect the following:
    • New O-ring and Water pump. Torque the bolts to 10 ft. lbs. (14 Nm).
    • Coolant hose to the pump
    • Coolant inlet pipe. Torque the fastener to 11 ft. lbs. (15 Nm).
    • Dipstick tube. Torque the bolt to 89 inch lbs. (10 Nm).
    • ECT sending unit to the dipstick tube
    • Engine wire harness. Torque the bolt to 89 inch lbs. (10 Nm).
    • Radiator fan. Torque the bolts to 52 inch lbs. (6 Nm).
    • Coolant reservoir
    • Front transmission mount. Torque the bolt to 47 ft. lbs. (64 Nm).
    • Upper and middle timing belt covers. Torque the bolts to 62 inch lbs. (7 Nm).
    • Right side transmission mount and insulator. Torque the bolt to 47 ft. lbs. (64 Nm).
  7. Fill the cooling system.
  8. Start the vehicle and check for leaks, repair if necessary.
1.8L ENGINE
    • Drive belt
    To install:
  4. Install or connect the following:
    • New O-ring and water pump. Torque the bolts to 8 ft. lbs. (11 Nm).
    • Drive belt
  5. Fill the cooling system.
  6. Start the vehicle and check for leaks, repair if necessary.
Jan 02, 2011 | Chevrolet Metro Cars & Trucks
How do i take off the old water pump on 1996 geo metro 4 cyl?
Removal & Installation
  1. Disconnect the negative battery cable.
  3. Remove the air cleaner.
  4. Remove the suction pipe bracket for the A/C compressor, if equipped.
  5. Loosen but do not remove the 4 water pump pulley bolts.
  6. Raise and safely support the vehicle.
  7. Remove the lower splash shield.
  8. Remove the A/C compressor drive belt, if equipped.
  9. Remove the alternator drive belt.
  10. Remove the crankshaft and water pump pulleys.
  11. Remove the timing belt.
  12. Remove the oil level dipstick and tube.
  13. Remove the alternator adjusting bracket from the water pump.
  14. Remove the water pump rubber seals.
  15. Remove the water pump mounting bolts and nuts and remove the water pump from the engine.
Water pump mounting location
  1. Clean the gasket mating surfaces thoroughly.
  2. Check the water pump by hand for smooth operation. If the pump does not operate smoothly or is noisy, replace it.
  3. Install the pump using a new gasket. Tighten the bolts to 115 inch lbs. (13 Nm).
  4. Install new rubber seals.
  5. Install the upper alternator adjusting bracket and tighten the bolt to 17 ft. lbs. (23 Nm).
  6. Install the oil level dipstick and tube.
  7. Install the timing belt.
  8. Install the water pump and crankshaft pulleys. Leave the water pump pulley bolts hand-tight.
  9. Install the alternator drive belt.
  10. Install the lower alternator cover plate and tighten the bolts to 89 inch lbs. (10 Nm).
  11. Install the A/C compressor drive belt, if equipped.
  12. Install the lower splash shield and lower the vehicle.
  13. Tighten the water pump pulley mounting bolts to 18 ft. lbs. (24 Nm).
  14. Adjust the water pump drive belt tension and tighten the alternator adjustment bolt to 17 ft. lbs. (23 Nm).
  15. Install the suction pipe bracket for the A/C compressor, if equipped.
  16. Install the air cleaner.
  17. Refill the cooling system.
  18. Connect the negative battery cable.
  19. Start the engine and check for leaks.
83667f6.gif Water pump assembly showing rubber seal location
    CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  3. Remove the air cleaner assembly.
  4. Loosen but do not remove the four coolant pump pulley bolts.
  5. Raise and support the vehicle safely.
  6. Remove the lower splash shield.
  7. Remove the air conditioner compressor drive belt.
  8. Remove the lower alternator cover plate bolts, loosen the alternator adjusting bolt, and remove the drive belt.
  9. Remove the crankshaft pulley.
  10. Remove the coolant pump pulley.
  12. Remove the oil level dipstick and guide tube.
  15. Remove the water pump mounting bolts and nuts. Remove the water pump from the vehicle.
To install:
  3. Install the pump using a new gasket. Tighten bolts to 115 inch lbs. (13 Nm).
  5. Install the upper alternator adjusting bracket and tighten bolt to 17 ft. lbs. (23 Nm).
  6. Install the oil level dipstick and guide tube.
  8. Install the water pump pulley and leave the bolts hand tight.
  9. Install the crankshaft pulley.
  10. Install the water pump/alternator drive belt.
  11. Install the lower alternator cover plate and tighten bolts to 89 inch lbs. (10 Nm).
  12. Install the air conditioner compressor drive belt by releasing the tensioner pulley and installing belt.
  13. Install the lower splash shield and lower vehicle.
  14. Tighten water pump pulley mounting bolts to 18 ft. lbs. (24 Nm).
  15. Adjust the water pump drive belt tension and tighten alternator adjustment bolt to 17 ft. lbs. (23 Nm).
  16. Install the air cleaner assembly.
  19. Start the engine and allow it to reach operating temperature. Check for leaks and refill cooling system as necessary.
Mar 06, 2010 | 1996 Geo Metro
COMPRESSOR ONLY GOES UP TO 65 LBS.
this unit should have a pressure switch that cuts the unit off and on with a adjustment to set the cut out .most switches have two adjustment screws.one of them tells the unit to kick on when the pressure is getting low.the other adjustment will raise the pressure to the desired amount.
Jun 16, 2009 | Northern Industrial 2 Hp Twin Tank...
Stiff turning
you could be low on pwer steering fluid. CV joints won't affect steering. That is for powering the wheels.
Very important. Make sure shop did not overtighten a/c belt. If they did, you could be in danger of breaking your crankshaft snout. It may be a good idea to check that.
Also, did they tighten the power steering belt correctly?
Did this steering issue sstart after repairs
go here for help
http://autos.groups.yahoo.com/group/villagerquest/
  1. The tension for the water pump and power steering drive belt should measure 603-691 N (135-155 lbs) for a new drive belt, 495-583 N (110-130 lbs) for a used drive belt. The limit for drive belt tension is 196 N (44 lbs).
    1. Adjust the water pump and power steering drive belt tension as follows:
    2. Raise and support the vehicle.
    3. Remove the RH front fender splash shield (16102).
    4. Loosen the water pump and power steering pump drive belt idler pulley locknut.
    5. Tighten the drive belt tension by turning the water pump and power steering pump drive belt idler pulley adjustment bolt counterclockwise.
      1. Tighten the water pump and power steering pump drive belt idler pulley locknut to 33-37 Nm (24-28 lb-ft).
      1. Install the RH front fender splash shield.
      Deflection Adjustment
      1. NOTE: If the drive belt has been in service for some time, it should be inspected before adjustment. A drive belt that is severely glazed, frayed, cracked, or contaminated with oil must be replaced. Minor cracks in the back of the drive belt are acceptable as long as no large pieces are missing.
        Apply 98 N (22 lbs) of pressure to the drive belt at a point midway between the power steering pump pulley and the water pump pulley.
        1. NOTE: Always check the drive belt deflection when the engine is cold, or has been stopped for at least 30 minutes. A drive belt is considered new if it has been used on a running engine for less than five minutes.
          The drive belt deflection should measure 8-10mm (0.31-0.39 inch) for a new drive belt or 10-12mm (0.39-0.47 inch) for a used drive belt . The limit of deflection is 16.0mm (0.63 inch).
        1. If the drive belt deflection is not as specified, adjust the water pump and power steering pump drive belt tension. Refer to the procedure in this section.
  1. The tension for the A/C compressor drive belt should measure 603-691 N (135-155 lbs) for a new drive belt or 495-583 N (110-130 lbs) for a used drive belt. The lower limit for drive belt tension is 196 N (44 lbs).
    1. Adjust the A/C compressor drive belt tension as follows:
    2. Loosen the A/C compressor drive belt idler pulley tensioner bolt.
    3. Tighten the A/C compressor drive belt idler pulley adjustment bolt.
May 25, 2009 | 1995 Mercury Villager
Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
1.6L Engine
A/C Compressor Belt
  2. Loosen the A/C compressor mounting bolts.
  3. Pivot the A/C compressor towards the engine in order to relieve the tension on the belt.
  4. Remove the A/C compressor drive belt from the pulleys.
To install:
  1. Properly route and install the A/C compressor drive belt on the A/C compressor, the power steering (if equipped), and the crankshaft pulleys.
  2. Adjust the A/C compressor drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the A/C compressor mounting bolts to 13-20 f t. lbs. (18-28 Nm).
  4. Connect the negative battery cable.
Alternator Belt
  2. Remove the power steering pump and the A/C compressor drive belt.
  3. Loosen the generator mounting bolts.
  4. Pivot the generator towards the engine and remove the accessory drive belt.
To install:
  1. Properly route and install the generator drive belt on the pulleys.
  2. Adjust the alternator drive belt to obtain 6-8 mm (0.24-0.32 in) deflection for a used belt or 5-6 mm (0.20-0.24 in) deflection for a new belt.
  3. Tighten the generator mounting bolts to 17 ft. lbs. (23 Nm).
  4. Install the power steering and the A/C compressor drive belt.
  5. Connect the negative battery cable.
Power Steering Pump Belt
  2. Loosen the power steering pump mounting bolts.
  3. Pivot the power steering pump towards the engine in order to relieve the tension on the belt.
  4. Remove the power steering pump drive belt from the pulleys.
To install:
  1. Properly route and install the power steering pump drive belt on the power steering pump and the crankshaft pulleys.
  2. Adjust the power steering pump drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the power steering pump mounting bolts to 22 ft. lbs. (30 Nm).
Apr 26, 2009 | 2001 Chevrolet Tracker
Air Tools & Compressors Logo
151 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
