When I try to play a bluray through my xbox one on the Toshiba tv a message comes up about using another tv input or the Hdcp rights management not being supported.The only 2 inputs that the xbox cable fits are the HDMI ports. Neither of these work for the bluray.
The formats that Xbox 360 supports include: MP4, M4V, MP4V, and MOV. So all you need to do is find a proper Blu-ray ripper that can help you convert Blu-ray to MP4 or other supported formats.
Here's one that's been getting positive reviews from users: Leawo Blu-ray Ripper.
It supports a lot of different formats, including the 4 formats that the Xbox 360 supports.
Know more details: Does Xbox 360 Play Blu-ray
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr
I have lost my manual for the lct27ta. Have you gone into the menu and setup the hdmi port?
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
SOURCE: Toshiba REGZA 37AV500A LCD TV
Does this happen with all the HDMI inputs. If only the one then jack is bad. Replace the main board. If on all HDMI inputs see if replacing the cable helps.
