Question about Akai Mpc1000 Music Production Center
My mode button on MPC 1000 broke... can't find replacement part
Any ideas on where to find a replacement MODE button? for mpc 100
thanks
w
Mpcstuff.com vstservice.com hiphoptools.com
Posted on Sep 04, 2010
Mpc 1000 loud static
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Mar 31, 2014 | Akai Mpc1000 Music Production Center
Help with using usb chord and sony vaio lap top.
Have you tried a different usb port or different usb cable also boot off your laptop and connect then connect the mpc 1000 and boot it up also make sure you have install the correct software for it
Jun 26, 2012 | Akai Mpc2500 Music Production Center
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
Mpc2500 mode button snapped off. i opened the mpc and removed the mode button. How can I get a new button?
You might try this site:
http://www.mpcstuff.com/mpc2500stuff.html
If the shaft/actuator snapped off a part on the board, then you will have to do unsoldering and soldering. Removing solder from the boards without the proper tools may damage the circuit board.
Jan 03, 2011 | Akai Mpc2500 Music Production Center
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
When I have my instrument cables coming out of the stereo outs of my mpc 2500 but it out come out mono. I don't know how to make it come out stereo. Is my mpc 2500 broke
To get stereo you must record in stereo or "PAN" individual inputs to one side or the other to create seperation. Your device is NOT broke.
Read your manual about panning.
Aug 04, 2010 | Akai Mpc2500 Music Production Center
I have an older mpc 1000 & just today it started changing the programs & number of bars of the sequence I was making when I pushed the cursor.
There is probably a switch problem. IF these use the conductive rubber contact type switch buttons where a "pill" of conductive rubber is pressed onto a circuit board with traces, CLEAN the contact rubber AND the circuit board with 99% isoprophyl alcohol and Q tips. This type buttons feel "Rubbery and squishy" when pressed.
If the buttons have a hard tactile feel, then check for a bad button that might have broken internal parts and replace it... OFTEN you can tell by the "feel" when pressing compared to others.
In either case, disassembly and service is required.
May 12, 2010 | Akai Mpc1000 Music Production Center
Akai MPC 1000 is stuck in USB mode
I'm having the same problem. This is my second MPC 1000 and my first one didn't have this problem. I bought one of the first one-thousand MPC 1000's sold in the US. I loved it. I sold it for rent, boo hoo. I'm glad to have another one back in my life. But sad to see it having issues already. I've only had it for a week. I have emailed Akai regarding this issue. I'll post pack here if they give me a good fix.
Mar 25, 2010 | Akai Mpc1000 Sampling Music Production...
Mpc 1000 beginner
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
Jan 21, 2010 | Akai Mpc2500 Music Production Center
Is it a bad idea to fly with my akai mpc 2000?
Good idea to carry it with you. Fluctuating barometric pressure will not affect it.
May 27, 2009 | Akai Mpc1000 Music Production Center
Akai Mpc1000 Music Production Center Logo
433 people viewed this question
Top Akai Music Experts
Michial Gueffroy
ray gallant
Are you an Akai Music Expert? Answer questions, earn points and help others
