Question about Radio Shack Radio Communications
I need to program my realistic police scanner.
I don't know how to go about programming my police scanner and i don't even know what any of the keys do. i just want to find the frequencies that i will need for the town that i live in. i live in Zephyrhills, Fl.
  • 3 Answers
For your frequency, go to the local radio shack and ask them to look up the frequency. If you have nothing to fear from your local jurisdiction, go directly to them and ask for the frequency. Programming is the easy part and obtaining the frequency not difficult.
Posted on Feb 16, 2010
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
How do i program realistic pro-59 scanner
http://support.radioshack.com/support_electronics/8567.htm
don't know what you will pickup. Nearly all law enforcement, ems, fire have gone to digital trunked systems that are encoded. The above link has a link to the operating manual. You will need to know the frequency of whatever you are wanting to listen to.
Aug 28, 2016 | Radio Communications
Will Realistic Pro 2021 receive digital frequencies?
If it does not say digital on the scanner the answer is no. If it does, most likely it is a trunking system and will require programming using software and a computer.
Nov 07, 2014 | Radio Communications
I have a Uniden BC560XLT police scanner. I don't know how to use it.
Why not go to the Uniden website for information. You may be able to download a copy of the manual for your scanner or get some basic information regarding programming
Apr 05, 2013 | Radio Communications
I can't get my uniden bcd396xt police scanner to talk. it will scan, but not talk
Hi Sue,
No it's not a Police scanner, rather a radio scanner.
I will scan, but not receive transmissions.
Two reasons for this:
1. Do you have any frequencies programmed in the scanner, if not, there's your first reason answered.
2. Do you have frequencies programmed but the channels are locked out? If so, there's reason 2 answered.
To unlock channels, you need to press Mon/Hold key to stop the unit from scanning. Now press mon/Hold key and as you do so, notice if you have frequencies programmed and not just a bunch of zeros showing on your display. If zeros are displayed, example: 000.0000MHz, then you need to program the scanner with your favorite frequencies, and I advise that Police should not be programmed. If you do have frequencies programmed, then using the Mon/Hold keys as stated above, go through each channel and unlock each channel using the L/O key, until the L/O icon on the display goes out.
I Hope I have assisted you with your query.
Cheers,
Peter
Mar 11, 2013 | Radio Communications
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
How do you set the scanner to your local police or
First you need to know what frequencies are in use in your area. For a comprehensive database, visit:
To enter (program) a frequency for future scanning:
- Slide the MODE switch to Scanner
- Press the E (PGM) key. This will turn on the PGM indicator at the top right of the display.
- Press the UP or DOWN arrow (above the SCAN and HOLD keys) to advance to the desired channel, OR enter the channel number using the keypad.
- Press HOLD
- Enter the frequency, including the decimal point (e.g. 155.67).
- To continue programming, use the UP or down key to advance OR enter a channel number, press HOLD, and continue programming as above.
When you're finished programming, press HOLD or SCAN.
I hope this helps. I have a BC370CRS on my desk, and I found that the programming is fairly simple -- once I got used to it.
NOTE: The BC370CRS will NOT work with trunked or digital radio systems. If these are in use in your area you will need a different scanner to listen in.
Dec 25, 2009 | Uniden BC370CRS Base Scanner
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Realistic pro-54 scanning reciver
this unit requires crystals for each freq.
Oct 21, 2007 | Radio Communications
Radio Communications Logo
911 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
