Question about EliteGroup PT800CE-A Motherboard
I need to reconnect the sound pins to the motherboard. there are 7 pins and i need the mapping
    Problem Solver:
  • 7 Answers
I understand that you need to reconnect your audio pins to your front panel. attach is link and the image of the mapping you request.
LINK:
http://i14.photobucket.com/albums/a304/ran_ixz/AUDIOPINConnectionmap.jpg
IMAGE:
[IMG]http://i14.photobucket.com/albums/a304/ran_ixz/AUDIOPINConnectionmap.jpg[/IMG]
Posted on Jun 17, 2009
Bios recovry
Press F8,F12 or whatever your PC bios info. you see when you turn on the PC. Then you can access the bios.
Jan 14, 2015 | Computers & Internet
No display
hi friend...!!!!!!
there are some steps which you need to follow..
1) you need to clean your ram with blank white paper..
2)you need to disconnect all your power connections which is attach with harddisk, cd drive, 24 or 20 pin connector and 4 pin display connector on yourmotherboard every connection which is form S.M.P.S.. reconnect all connections.
3)reconnect your C.M.O.S battery which is on motherboard..
hope your problem solved
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
Sep 05, 2011 | Intel D945GCCR Motherboard
Cpu fan stop few second after starting pc
Hello,have you installed new motherboard or CPU?
Follow these steps again
1) Disconnect the power cord from the back of the computer & open up the case.
2) Wear an anti-static glove or at very least discharge your static by touching a metal surface or power supply
3) Disconnect the main 20pin ATX power connector from the motherboard & the square 4pin ATX2 power connector
4) Remove any PCI cards you have & disconnect ALL drive cabling from the MOTHERBOARD. Also disconnect any internal USB fly leads from the motherboard.
5) You should now have ONLY the cpu+heatsink/fan, memory & video card installed. Locate the round silver battery in the bottom right corner of the board. Just below it, you'll see a plastic jumper cap. This cap should be covering 2 pins (pins 1 + 2) with pin 3 bare. It will be marked JP1. Move the jumper to cover pins 2-3 instead. Leave in this position for about 30 seconds, then return the jumper to its original position (pins 1-2).
6) Reconnect the square 4pin ATX2 power connector & the main 20 pin ATX power connector. Make sure that the case speaker or buzzer is connected also.
7) Make sure the only external devices connected are the keyboard/mouse & monitor. Reconnect the power lead & power on the system
Let me know what happens
Feb 06, 2010 | ASUS M2N68-AM SE2 Motherboard
IT IS NOT WORKING
Run this diagnostic
Test Procedures
1. Check if DTC P0110 is set in addition to DTC P0105 or P0106. If DTC P0110 is set, go to next
step. If DTC P0110 is not set, go to step 3 .
2. Turn ignition off. Disconnect MAP sensor 4-pin connector. Measure resistance between ground
and MAP sensor connector terminal No. 4 (Green wire). If resistance is one ohm or less, replace
MAP sensor. If resistance is more than one ohm, repair open in Green wire between MAP sensor
and ECM connector terminal No. 48. After repairs, clear DTC and verify MAP sensor operation.
3. Turn ignition off. Disconnect MAP sensor 4-pin connector. Measure resistance between MAP
sensor connector terminals No. 1 and 4 (component side). Resistance should be about 30,000
ohms. If resistance is as specified, go to next step. If resistance is not as specified, replace MAP
sensor. After repairs, clear DTC and verify MAP sensor operation.
4. Turn ignition on. Measure voltage between ground and MAP sensor connector terminal No. 2
(Red wire). Voltage should be about 5 volts. If voltage is as specified, go to next step. If voltage is
not as specified, repair open in Red wire between ECM connector terminal no. 44 and MAP
sensor connector terminal No. 2. After repairs, clear DTC and verify MAP sensor operation.
5. Turn ignition off. Disconnect ECM 63-pin connector. Check for continuity between ground and
MAP sensor connector terminal No. 1 (Green wire). If continuity does not exist, go to next step. If
continuity exists, repair short to ground in Green wire between MAP sensor and ECM. After
6. Reconnect MAP sensor connector and ECM connector. Turn ignition on. Backprobe MAP sensor
connector and measure voltage between ground and MAP sensor connector terminal No. 1 (Green
wire). Voltage should be 0.2-4.5 volts. If voltage is as specified, go to next step. If voltage is not
as specified, replace MAP sensor. After repairs, clear DTC and verify MAP sensor operation.
7. Check ECM connector for loose or damaged terminals. If problem exists, repair ECM connector.
If problem does not exist, replace MAP. Clear DTC and verify system operation. If problem still
exists, replace ECM. After repairs, clear DTC and verify system operation.
Good luck and hope this helps. If the car does not start diconnect the MAP sensor to get you to the parts store if you need it to get you there.
May 25, 2009 | 2001 Hyundai Elantra
No sound
If you have used a headphone or the line out recently reconnect it and see if you have sound. If you do the pin is stuck in the jack. Try inserting and removing the headphone or lineout cable a few times.
Hope this helps
May 05, 2009 | Garmin Nuvi 660 GPS Receiver
Reconnect front usb
Visit the manufecturer's website and find the users manual. Usually such informations are given in the users manuals. (ehteshamhusain@gmail.com)
Apr 27, 2009 | Computers & Internet
Gat compaq motherboard from geeks, need front panel settings 2830
Would need the exact mother board model. Usually the it's a group of eith to ten pins set closely together. There should be s map on the board to tell what is pin is.
Mar 27, 2009 | HP Compaq Motherboard
NEED SCHEMATIC FOR EMACHINE T2984
If you look closely, you would see written: power, reset, hdd led, power led(normally at the left bottom corner of the motherboard). If you look at the mapping well, you will see where how each double pins represents one of these. Simple slot the power button wiring into the one that maps with the power position.
You can also test this by touching the two pins together with with a metal say, a screw driver. If its the power, the machine will turn on.
Nov 10, 2008 | E-Machines eMachines Desktop PC
SL-75KAV
Here ya go http://www.motherboards.org/files/manuals/118/75kav.pdf
This has all the pictures you will need to reconnect everything. If this helps be sure to rate my help.
Jan 22, 2008 | Computers & Internet
WinFast 6100K8MA-RS motherboard drivers
There is no sound because it wants to route the sound through your front inputs. If you don't have any front audio inputs, you must short out pins 6-7 and pins 9-10 on the front audio connector (F_Audio) which is on the back left of the motherboard.
Nov 20, 2007 | Computers & Internet
EliteGroup PT800CE-A Motherboard Logo
83 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
