Question about Dehumidifiers
Our dehumidifier is running great but has not put out any water for about 30 hours. I empty it every three to five days and this has never happened. Can you assist me? Thanks!
    Sergeant:
  • 340 Answers
Does your area have a higher than normal humidity? mine is doing about the same in the Midwest
Posted on Jun 17, 2009
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
Is there a special code to direct water to pump, dump bucket or drain
That would be the "Pump" button on the control panel. When you press it, your dehumidifier display should indicate "PUMP", and the unit should start pumping water out that little port at the center rear of the dehumidifier.
Alternatively, you could stand the dehumidifier on a counter and direct your waste water out the larger hose connection into a sink.
I personally carry it (more than five gallons per day) upstairs to the laundry, because it's distilled water - the softest water you can get. Works GREAT in the washing machine. 8) 8) 8)
Jul 30, 2014 | DeLonghi DD50P Dehumidifier
Just bought a dehumidifier in the ground level of a high ranch I am very frustrated because I dump the water every day I waas told to keep the humidity at 45- 50 but it keeps on going up This seems to be a...
It isn't necessary you run it 24 hours a day. You can set it to be on for 2 or 4 hour intervals and then it Turns OFF. However, I am a bit concerned that you have the humidity extraction level set a bit high for a basement application. 50% is more than most basements need to be. Lowering it to 35%, will remove more humidity and eventually will run for shorter periods of time. It takes several days of operation for the dehumidifier to get the humidity under control.
If you have a floor drain in your basement, you can use a hose to daring the water, rather than having to empty the bucket daily (which is not that unusual). See your Owner's Manual on how to connect a 48" length of garden hose to the dehumidifier.
I hope this helped you & thanks for choosing FixYa.
Sep 17, 2011 | Friedrich Dehumidifiers
I purchased a 45 pint/day dehumidifier model # DD45P last year and it worked great. We needed to empty it almost every day as it was located in our lower level at a lake home. We have just returned to our...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 11, 2011 | DeLonghi Dehumidifiers
I turn my dehumidifier on and let it run for hours, but when I go to empty the bucket, there is no water in it.
heatman101
Mar 01, 2011 | LG DH504E GoldStar Dehumidifier
Have had the unit on for 24 hours now & the water tank has remained empty all this time. Any ideas on this Amcor Dehumidifier dc100 ?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 21, 2011 | Amcor AHD65 Dehumidifier
My amcor dehumidifier tc120 has started clicking recently and now its out put is poor the unit is used in a cellar just to keep control of humidity it works 24/7 then has few days off when full untill i...
heatman101
Jan 17, 2011 | Amcor DC930 Dehumidifier
Dehumidifier makes the room too hot where it is running. does very good removing water need too empty 50 pt every 24-30 hrs.
The dehumidifier does not heat or cool, but the compressor running will produce some heat and it can make a room hotter...
heatman101
Aug 29, 2010 | GE AHG40LJ Dehumidifier
For the last month or so, the dehumidifier runs all day long and pulls very little water out of the air. The air humidity reads at 65%, with the dehumidifier set at 50%. I can smell the difference in the...
heatman101
Jun 19, 2010 | Maytag M7DH45B2A Dehumidifier
Unit works fan runs lights turn on but no water in the bucket,
Some units use the condensate water to cool down the condenser coil. This is why no water is present. If water is leaking from the unit or you are still sceptical about this problem, I would call for service.
Mat
Jul 16, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifiers Logo
106 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
