Question about Frontgate Refrigerators
How can i change the jenn-air side by side model water filter?
  • Frontgate Master
  • 3,361 Answers
Unscrew it to the left and pull it out.
Posted on Jun 16, 2009
Jenn-Air Refrigerator JS42SEDBDA Model 12606032GJ was in house when I brought house. No user manual. Does this model have a water filter? The refrigerator has the words water filter,and underneath that...
Remove the compressor cover to locate the filter.
www.appliancepartspros.com has the filter.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-refrigerator-water-filter--puri-clean--item-number-ap4343710.aspx
Aug 20, 2011 | Jenn-Air JS42SEDBDA Stainless Steel Side...
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Tip
New Jenn-air refrigerator, Model #JFC2087HRS, water filters do not work...
The new Jenn-air refrigerator, model #JFC2087HRS, water filters (UKF8001) do not work correctly. Water flow is slow. I have called the manufacturer but cannot get any help from them. They insist they work fine. I have tried several of the new ones. The problem seems to be that the small ramps on the new water filters are not tall enough to push the small plungers sufficiently into the water dispenser. I have added a small piece of plastic (glued) to the ramps on the water filter in order for them to work better, but not as good as old ones worked (UKF8001AXX). The next best thing is to buy the old filters if you can find them.
on Feb 24, 2014 | Jenn-Air JFC2087HRS Side by Side...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
Water filter location on 22cuft side by side.
The most likely area for the filter on a Jenn-Air is inside and top right hand corner of the fresh food compartment. A Jenn-Air model number looks like this JSD2388AEW Send me your model number and I will send you a Service Manual, Thanks, Sea Breeze
Jan 16, 2010 | Jenn-Air Refrigerators
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
How do I reset the change water filter light?
On my Fridge you press and hold the reset button for 3 seconds if that dont work has the filter been replaced?
Apr 04, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Frontgate Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you a Frontgate Refrigerator Expert? Answer questions, earn points and help others
