Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley davidson evo motor wont turn over...just clicks
Have a custom motorcycle runing a harley davidson evo engine. had the bike running one day, then went to start it the next day, and the starter just clunks one time, but doesn't turn the engine over. battery is showing full charge (even put it on charer overnight) and is new. connections look good, but when i try to start, wire from start switch to starter gets REALLY hot. like i said, the motor doesn't turn over...just "clunks" one time. the guy that built the bike is 5 hours away and not available to help. any ideas on what i can try?
  • 379 Answers
Pull the spark plugs out and hit the starter. This will make sure that the engine is not locked up. If the starter does not turn the engine, put the bike in first gear and have someone push you, making sure the engine is free. If the engine is OK, your starter is probably jammed and needs replaced. That wire getting hot is a dead giveaway something is locked up tight...starter or engine. If ya have a large hi-performance engine in the bike, chances are your stock starter won't do the job.
Posted on Jun 26, 2009
How to remove the starter motor on 2005 Harley sportster
Hi Hubert, I am sorry you can't find the first and best tool you ever bought for your Harley Davidson but despair not for a mere $6.50 you can download another one. For more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
evo sportster starter removal from evo sportster problem 11
Servicing rebuild your starter motor
Harley Davidson Manuals Mark Workshop
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 31, 2015 | 2005 Harley Davidson XL 1200 C Sportster...
Harley sportster headlight and brake light work but not the turn signals. Engine lights does not come on and bike wont start
The soft click sounds like the starter relay. Check that out first and see that current is getting through when it soft clicks. ARE there any codes set??? What led up to this???
Apr 14, 2014 | 2004 Harley Davidson XL 883C Sportster...
I own a custom built motorbike (from tyres up) with a Harley Davidson 1340 Evo stock unit engine. It is kick start and I want to convert it to electric start. I have been told that I would require a 5...
Yes, you can put an electric start on the bike. I've seen plenty of customs with Evo engines, four speed transmissions and electric start. You'll have to change the primary setup of the bike. Does your outer clutch basket have a ring gear on it for a starter to turn? If not, you may have to change your clutch as well. The starter bolts to the primary plate. Even the 1965 Panhead with four speed transmission had an electric starter. I'm sure you can do it.
Good Luck
Steve
Jul 27, 2011 | Harley Davidson FXST Softail Standard...
Starter issues
try tapping on the starter motor/solenoid, it sounds like the solenoind is engaging(the clunk you hear) but the starter is not turning if the wire is getting hot it could be the starter is frozen up.
Jun 19, 2009 | 2004 Harley Davidson FXSTS - FXSTSI...
Custom bike....starter "clunks" and does not turn over
Sounds like your jack shaft isnt engaging into the bushing in your outer primary... you should pull off the outer primary and try carefully filing the edges off the bushing... Also check that the jack shaft has been properly installed.... This problem is common on customs
Jun 19, 2009 | 2001 Harley Davidson FLSTS Heritage...
Starter and possible wiring issues with custom bike
Did you try removing the starter and testing it on a "bench"? Sounds like it might be "jammin" up. Loose, misalignment, it's worth a try and doesn't cost anything. good luck
Jun 18, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
My bike was runing good it,s a94 fatboy the other
Sounds like your voltage regulator is bad or come unplugged
May 09, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
2,010 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
