Aver media center video gaming plug in does not work
When you open windows media center and open avermedia video gaming plugin it says unknown error and stops. please help!
Reinstall the windows media player.
Posted on Jun 18, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Xvid for windows vista
I've spent a lot of time this weekend finally setting up Windows Vista Media Center, and I suddenly realised that Vista Media Center won't play Xvid and Avi files even if Windows Media Player will. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the Media Control Plugin For Windows Vista Media Center.
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)). FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
The Media Control Plugin for Windows Vista MCE also adds the following additional features:
  • Switching embedded audio and subtitles streams while playing a video: works with AVI, OGM, MKV
  • Switching between external subtitle files (.SRT, .SUB)
  • Switching between FFDShow presets (audio & video)
  • Setting and loading bookmarks inside a video with visualization of the pictures of the saved bookmarks
  • Real fastforward (and rewind) exactly like in the TV module (with 3 different speeds)
  • Switching and setting post-processing filters in FFDShow (video filters only)
  • Separate application to assign keyboard/remote control shortcuts to the commands and the MCML pages of the plugin.
  • Full remote control support (6 buttons are mapped by default, but this can be changed)
  • Default mapping (works in full screen while watching a video, except the blue button that is always caught) :
    • Fast forward / rewind buttons
    • Blue button : loads the startup page of the plugin
    • Red button : switches audio stream
    • Green button : switches subtitle stream
    • Yellow button : switches subtitle file
May 06, 2011 | Dell Computers & Internet
I am using an internal TV card model "Aver tv go
I am using an internal TV card model "Aver tv go 007". recently I have changed the Intel motherboard of my pc with an Asus motherboard. Sound is not available now. It shows "no suund card is available"Please help mr.RegardsMamun this is my problem
Feb 25, 2011 | Avermedia AVerTV GO 007 Plus/FM Plus...
Hello... Today i Bought a New Aver Media DVD EZMaker USB Gold..I am running it on Windows XP SP2... i got a Problem... i am not able to capture(also in preview) the video in original color format......
problem is that any today products are not compatible with a win operating system ( Win XP) which has not been supported by Microsoft for the past 10 years or longer
You may have to install win 10 to get it to work propely
Jan 09, 2018 | Avermedia AVerDVD EZMaker Video Capture
AVerMedia M791 PCIe Combo does not recognize antenna
wipe all tv related software from pc delete tv card entry from device manager and reeboot windows will find card and ask to install software again this should fix it if not card may be faulty should check card in another pc before trashing it.
Nov 10, 2009 | Computers & Internet
How can i play AVI files on my media center/player on vista
Windows Vista Media Center won’t play Xvid and Avi files, even if Windows Media Player will play these files. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the media control plugin for Windows Vista Media Center.
To install the Codec please click on the below link or copy the URL and paste it in your web browser..
http://damienbt.free.fr/index.php#download
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)) FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
have any other queries, please let me know..
Thank you.....
Oct 13, 2008 | Computers & Internet
Computers & Internet Logo
709 people viewed this question
Alun Cox
David Payne
David Payne
