Question about Sony Playstation 3 (PS3) Console
My ps3 is int able to detect my ip adress
Even though i hooked it straight up to my modem
  • ss4byrdman Jun 16, 2009
    should i connect it to my ps3 first or after i turn it back on
    Problem Solver:
  • 11 Answers
Once you connect to the modem you must reset the modem, unplug it for the power source for 2 whole minuets then reset the ps3 and this should solve ur problem
Posted on Jun 16, 2009
How to connect my motorola surfboard sb5101 cable modem ot my ps3
Hi turn both modem and PS3 off. Then connect the ethernet cable from the modem to the PS3 and then turn the PS3 first. Then after the PS3 is completely on, then turn the modem on so the PS3 will get the modem's IP adress.
I recommend you get a router and connect it to the modem and the PS3 to the router. It's way better. I hope this helps.
Apr 29, 2010 | Arris SURFboard SB5101 Cable Modem
Cant find IP on hardwired PS3
is that modem setup to a computer before hand? you need it to be programed with a computer then after you access the internet, then hook up the modem to the ps3,
if you bought a new modem then you need to call your provider and have them program it
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
IP adress timing out on my PS3
you could try putting in the ip adress manuley.to get you ip adersses go to cmd prompt in cmd prompt type in ipconfig/all .
Jan 08, 2010 | Sony Playstation 3 (PS3) Console
Hello, i type in the modems address, 192.168.0.1 but it wont let me access the setting page to try to configure wireless settings, i'm running win 7 64 bit, and cant even find a dos command to ping with
To get to the DOS prompt , Go to start and type " cmd" enter. Then you can use the ping utility. I had a problem on a new dsl modem and after many hours trying to fix it, It was a bad modem. It worked for a week then nothing. They finally replaced it and it worked. Some time being new doesn't mean its not broken. I learned it the hard way.fd93cca.png
Dec 18, 2009 | NetGear DG834G Router
PS3: i can obtain ip adress but fail to connect to internet.
I would suggest that first you stop using the first modem. Then plug your computer into the modem and install using the comcast cd that came with your welcome package. If that doesn't work please tell me.
Jan 31, 2009 | Linksys Wireless-G Broadband Router
I cant get onto the internet with my playstation 3 .
If u can get online Playstation Network to the point wer features like adding friends become availible then there shiould be no problem. If you cannot sign in to playstation network then there is a something wrong with your network aettings. If an arror code comes up type into google something like "What does error code *********** on the PS3 mean???". Be specific
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
IP Adress Can't be Read By PS3
Well, I'm not completely sure how to help exactly. This problem sometimes prompts as "DNS" error followed by an error code. If it displays a DNS error, then your problem is that the PS3 cannot find the modem (and router if you have it connected that way).
DNS errors on the PS3 simply means that it cannot find (see) the modem/router.
One way of correcting this would be to reset your modem (and router if you have it connected that way)by unplugging it (from wall and power port). Keep it unplugged for 1 minute or so. Power down your PS3 at the same time.
Plug in your modem (and router if you have it connected that way) and allow for it to reset.
Now power on your PS3 and go to the network settings and establish a new wired connection. Follow the prompts and test the connection afterwards.
Mind you, this is a general means to solving the problem. Try this first to see if you are successful.
I do hope that this helps you.
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
Ip adress
go to the network connections page on your computer, then find your connection and right click it and move down to status... there should be a tab that says support... click it and you should see the ip address assigned to your modem by the ISP.
Nov 22, 2008 | Arris SURFboard SB5101 Cable Modem
Ps3
Can you give a little more information about your configuration? Are you connected at all? Do you know what is going on? Does your car have an automatic transmission? Do you have people hooked to the underground chopshop network? Have you relocated through a time portal? If you have, did you tell sony the problems people are having in the future with there PS3s? Did they commit you into an asylum? Did you call sonys tech support hotline? The number is 1-800-345-7669. I hope they can help you without having to unanswer your questions with more questions like these. If they don't know, I would suggest smashing it with a hammer.
Feb 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3 to internet
Difficult to explain but i'll try:
You got 2 options.
1. Buy a router and connect the modem to the router wan port and find a manual how to set it up. Then through your router you can connect (a lot of) pc's, laptops or ps3.
2. Buy an extra network card and a crosslink network cable cat5e. Use software like gatekeeper to connect both to internet.
maybe the second option is the best because sometimes isp providers register you mac adress(unique adress of your network device). It's not the fastest solution.
The first is the most professional but require some knowledge of routers, ppoa, pptp, fixed ip, Wan ip, and lan ip.
I did the second option a lot with speedtouch modems and draytek routers.
Good luck, let me know if you need more assistence.
Dec 29, 2007 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
