Question about LG WM2487H Front Load Washer
Lg washer won't spin
Lg wm2487hwm won't spin
    Scholar:
  • 105 Answers
Does it power on?
Does water come in at the beginning cycle? Do the lights come on?
Your motor has a warranty of 7 years from purchase date. Call 1-800-243-0000 for service.
Posted on Aug 02, 2009
How to replace a washer pump lg WM2487Hwm just a nose from pump....
pretty straight forward job. but you need to take front off for access. which means top comes off first. so must unstack washer/dryer. check out repairclinic.com or appliancepartspros.com for how to videos.
Oct 22, 2016 | LG WM2487HWMA Front Load Stacked Washer /...
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
Low rumbling noise and washer won't spin
Remove access panel and check to see if the belt is on.
Nov 12, 2012 | LG WM-2277HW Front Load Washer
Whats the red key and circle llso shows a OE code on LG steam washer wm2487hwm
OE on the LG means the washer is not draining or has a draining issue. When it happened to me I started by manually draining the washer and then running a spin cycle. In a pinch the work around was OK but I could never be certain the wash was complete. Also the wife hated it.
Finally, I dug in and went for a fix. All the hoses were clear and the pump seemed to be working (also the pump screen needed clearing). I found the problem to be a breather hose that runs from the top of the drum to one of the drain hoses. It was plugged and I took it off and blew it out. Problem solved.
Aug 05, 2012 | LG Washing Machines
Washer wont spin and makes a clicking noise
I have a LG front load and it won't spin or drain... Can u please help me
Jul 01, 2012 | LG WM1814CW Front Load Washer
We have a LG washer, model wm2487hwm, seems like it is not spinning oiut the water like it used to, clothes seem to be wetter than previously, whats the problem?
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 08, 2011 | LG WM2487H Front Load Washer
LG Tromm washing machine model WM2487HWM has an error code. First letter looks like a capital E without the top horizontal line. second letter is an E
That's 'te' standing for temperature error/ heating error. Before you call an engineer try emptying the washer then pouring a couple of kettles of boiling water into the drum and leaving for 30 minutes then see. Another thing is to empty a couple of packets of limescale remover into the drum together with a couple of kettles of boiling water (again!) and leaving overnight. It possibly needs de-scaling anyway ;-0) If these fail it will be an engineer call, sorry ;-0(
Good luck, John C
Mar 22, 2011 | LG WM2487H Front Load Washer
Rear bearing is going out (very loud on spin). Tech said it would be $900.00 to replace. Is it that hard to replace a rear bearing? Does the whole machine have to be disassembled, etc. About how much is...
rear bearing is generally included with the rear outer drum ***'y. seals and bearings are already pressed into it. it will require much disassembly of machine. hopefully, the motor rotor/stator/drum spider shaft is not damaged too.
Aug 13, 2010 | LG WM2487H Front Load Washer
LG WM2487H Front Load Washer Logo
455 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
