Question about HP Pavilion F1703 17" LCD Monitor
Computer monitor is white
My hp monitor has a white screen, replaced it with another monitor and it worked for a bit and now it is white, whats the problem
  • jedi_dunn Jun 17, 2009
    well you turn the power on the monitor and the screen is just white. there is nothing on it, the entire thing is white. i put my old monitor back on it and it worked for several days, now the screen is just white.. i put new cables and put on another computer and it is just a white screen.
  • 285 Answers
What do you mean, white screen?
It just went blank after a few minutes of use?
Anyway, you've already eliminated the monitor as the surce of this problem, so it can now be either the cable from your monitor to your PC or your graphics card. I suggest you try another monitor, and if that doesn't work, find someone to temporarily insert another graphics card into the system.
One of these should fix the problem,
Yannick.
Posted on Jun 16, 2009
Hp g6 white screen
You can use an external monitor to test this laptop. If your laptop works good with an external monitor, your laptop screen is dying and need to be replaced.
Mar 10, 2014 | Computers & Internet
White screen on hp w2007 LCD monitor.
Troubleshoot an HP LCD Monitor
HP makes a number of liquid crystal display, or LCD, monitors.
LCD monitors create an image by passing light through a liquid crystal solution that either blocks the light or allows it to pass through to a color filter.
LCD monitors are ideal for use with a computer as they present an excellent still image and cannot suffer pixel burn-in like other flat-screen display technologies.
Even quality monitors run into the occasional problem and need some basic troubleshooting before sending them in for service.
Check the power cord to make sure that it is plugged in securely to both the monitor and the outlet. If you are using a surge protector, remove it and plug the power cord directly into an outlet that you know is working.
Detach and reattach both ends of the cable running from your computer to your monitor.
If your HP LCD monitor has more than one connector, use the other one to make sure that the connector isn't the issue.
Remove any switch or extension cable that may be present between the computer and the monitor.
Restart your computer. A fresh start will correct many software issues.
Check the documentation of your video card to make sure that it supports HDCP, or High Bandwidth Digital Content Protection, since the screen may be blank when you are trying to watch high-definition content through a video card that doesn't support it.
Some older HP LCD monitors also do not support HDCP, so check your monitor documentation as well.
Go to your video card manufacturer's website and install the latest drivers for your video card. Instructions for installing the drivers will vary by manufacturer, but they should be listed with the driver software.
Change your resolution to a preset video mode to make sure that you aren't trying to operate the monitor in an unsupported resolution.
Different models of HP LCD monitors support different preset video modes.
All of the preset video modes for your monitor are listed in your monitor's manual.
Resolutions of 1024 x 768 and lower are supported by almost all HP LCD monitors.
Press the "Auto/Select" button on the front of the HP LCD monitor to correct any images that are dark or blurry.
If this does not correct the image, press the "Menu" button on the front of the monitor to bring up the on-screen display menu, where you can use the "+" and "-" buttons to scroll through the options and "Enter" to select the option that you want to change.
Adjust the brightness and contrast as needed by selecting them and using the "+" and "-" keys. Press the "Menu" button to exit the menu.
Press the "Menu" button to enter the menu, scroll to "Image Control" and press "Enter."
From here you can choose the "Auto-Adjustment" option and the HP LCD monitor will automatically adjust the horizontal and vertical positioning to center the screen.
The ability to adjust these settings is available only if you are using VGA inputs.
Contact your retailer or manufacturer for any additional troubleshooting steps for your particular model of HP LCD monitor.
If your monitor still has issues, you may need to send it in to be serviced.
HP Support
http://welcome.hp.com/country/us/en/support.html
Fix a White Screen on an LCD Monitor
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty.
You will need to troubleshoot these possibilities to determine which problem you have.
If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it.
Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot.
If your computer display does not show on the functioning LCD screen, try rebooting your computer.
If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance.
If your computer display shows normally on the working LCD screen, proceed to Step 2.
Unplug the LCD monitor with the white screen.
Disassemble the rear panel of the monitor with the small screwdriver.
Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor.
Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen.
See the References section for photos of the video cable for assistance.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Unplug the cable, checking for any debris or blockage.
Reconnect the cable firmly.
Reassemble the LCD screen. Plug it in and connect it to your computer.
If the screen is still white, you have a defective LCD screen.
You will need to replace it or take it to a professional repair service for assistance.
Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1).
After that you connect another working screen and test video.
For this purpose I'm using one of my test LCD screens.
My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image.
After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
Aug 04, 2013 | HP W2007 20.1 Widescreen Monitor
Monitor has white screen
Hi
After understanding your issue with the monitor I hate to say this but unfortunately you have to consider replacing your monitor.
Thanks for using Fixya
Feb 21, 2013 | HP w1907 LCD Monitor
What steps needed to get the blank screen on HP G70-257CL working?
Check the video connection that plugs onto the motherboard.
Oct 15, 2012 | HP G70-257CL Laptop Screen
Monitor looks pink in white areas.
ghrit, if disconnecting-reconnecting the vga cable 4 or 5 times won't cure your PINK screen, then you may have bad inverter supply or the "cold-cathode-fluorescent-lamps" might also be a bit tired-out and need replacing? Retrevo .com lists unit as over the hill but not ready to retire. Do some reading in my and other ("budmrtn" "buddymc") fixya profiles for info on what to do!!! Follow the links you find there to learn about pink screen and also black screen and blank n black screen conditions that occur with all brands of CCFL back-lit lcd monitors. Do some research here at FIXYA and pay a visit to YOUTUBE for video clips of "lcd monitor repair" "lcd monitor disassembly" so you have info for future use. Bye for now 12fixlouie
Aug 04, 2010 | HP w17e Monitor
Hp w1907 has white screen in vga and dvi-changed computers doing same thing-tried another monitor and it works on both computers
The all white screen indicates loss of 5 VDC to the LCD panel. Either the connector is not plugged in good or (more likely) the panel itself had failed. They can develop a short that blows the 5 V fuse on the panel. Replacing the fuse normally does not fix the problem.
Monitor Mike
Apr 30, 2010 | HP w1907 LCD Monitor
W19-1 turning white, with small breaks of black screen
there is an issue with the HP monitor which you using you need to replace it
Jul 17, 2009 | HP w19 19" LCD Monitor
My hp 1502 has a problem.screen is white,but LED not lighted.
You need to replace the bad electrolytic capacitors inside.
Monitor Mike
Apr 14, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Hp F1703 LCD Monitor gray/white Screen
Hi...there,
It's seems you got a busted AD board... Need to replaced a new one or replaced a new bios...
Nov 25, 2008 | HP Pavilion F1703 17" LCD Monitor
I have a problem with my hp 1702 please help!!!!
this means that your screen settings are not compatible with the game. like 16 bit color to 32 bit color. set the screen settings so that you can play. Display properties would let u adjust these colors.
Aug 11, 2008 | HP L1702 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
310 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
