Question about Panasonic KX-FPG377 Plain Paper Thermal transfer Fax
Replacing film after replacing film I get a message "check film" and "cover is open"
Try to sensor check.. press "menu # 9000 # *(ateris) 815" then remove the ink film.. try to trigger the white lever found near at thermal head can see it if you remove the ink film.. then look at the LCD.. while triggering the lever,, see if there is reacting on screen while triggering the lever sensor.. if no reaction or sometimes there is reaction.. you need to cleaned the sensor at the digital board....
Posted on Jan 30, 2008
I have a 660 sharp fax . when I 2turn it on its display shows. check cover,check film, check paper. how can I solve it ?
Replace the film, replace the paper(properly installed)and check all covers re-seat them, also check to make sure that the tab that goes into the machine for each cover is not broke if one is then copier thinks that cover is not closed. buy new film.
Mar 12, 2015 | Sharp Office Equipment & Supplies
The flash sometimes doesn't work and prints out white film
Hi, once you insert the new pack of film, first shot is without flash as it's eject the film cover which is a useless film cover that cover the film protect the film being exposed. after first shot, camera will have flash. but do not open the film cover again. if you open and take out the film it will expose to light and film turn out to be white.
Apr 13, 2014 | FUJIFILM Instax 210 Film Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Check Film and Cover Open: KX-FPC95
Check for slack in film between supply and take-up rollers. Manually advance take-up roller to remove slack before closing cover.
Dec 18, 2009 | Panasonic KX-FPC95 Plain Paper Thermal...
Have replaced film and unit keeps saying "cover open" or check film. I replaced film correctly twenty times.
On some units it is possible to install the film upside down( backwards) but since you've done it multiple times it is more likely that the sensor that sees the film is broken or blocked. Look for a small block with two little lenses. They don't usually break per se but can get blocked by debris like scraps of paper.
Good luck
Jul 27, 2009 | Panasonic KX-FPG378 Fax
Replaced film, unit say's "Check film, Cover open". Film is fine, cover is closed, can't figure ths out?
I had that problem once and I unplugged it for 5 minutes and then replugged it in and it was fine.
That's what worked for me.
May 30, 2009 | Office Equipment & Supplies
Opening the cover
This model print on Thermal transfer technology: there is a black film inside the fax.
Open the cover from the rght side with the green or grey button.
You can then see the black film.
Usually, the top part is the new, the lower is th used.
To know if the film is near empty, you can remove the film from its place and see which side is bigger.
Good Luck.
Mar 13, 2009 | Panasonic KX-FP101 Plain Paper Thermal Fax
Disney princess camera
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
Jun 30, 2007 | Pentax IQ Zoom 60S 35mm Point and Shoot...
Panasonic KX-FPG377 Plain Paper Thermal transfer Fax Logo
224 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
