When your phone gets black or broken or cracked, the first thought should be attempting to rescue your data from Android phone. However, since your Android phone gets black screen or broken screen, you can't access and perform your Android phone normally as usual, and you can not export Android data by connecting your device to computer via USB cable as well, for you cannot manually enable USB debugging mode on your phone. In this case, what should you do to recover data from Android phone with black screen? Just take it easy, you can easily resolve this problem with the Broken Android Data Extraction. Luckily, you have the Broken Android Data Extraction now so that you can restore everything you want from your Android phone with black screen without hassle. With it, you can easily access your Android data without enabling USB debugging manually on your Android phone with black screen. It allows you to enter the Download mode to scan your device for your Android data without perform the Touch screen. https://www.samsung-messages-backup.com/resources/recover-android-data-with-black-screen.html
This is probably too late but I really hope this can help you or others. 1,Possible Reasons for your iPhone's Black Screen of *****
A. Hardware Damage
B. Failed Software Update
2,Common Ways to Fix the Black Screen issue in your iPhone.
A. Perform a Hard Reset on your iPhone.
B. Restore Factory Settings using iTunes
3,Best Solution: Fixing your iPhone's Black Screen issue with FoneDog Step 1: Launch and connect. Step 2: Detect the Affected iPhone Device. Step 3: Proceed to the System Recovery Process. Step 4: Download the Firmware. Step 5: Perform Another Option for Firmware Download. Step 6: Repair in Progress. Step 7: Turn on the Device after Repair.
Turn the calculator on. Press and release the 2ND key, then press and hold the down-arrow key until the screen lightens. If you go too far, repeat the process with the 2ND and up-arrow keys.
