Question about Dynex 4-Port Ethernet Broadband Router (DX-E402)
Need to change the mtu settings on dynex router to use xbox how
Im having the same problem with a Zyxel router...
Posted on Jun 16, 2009
I need to change the MTU settings
To change your MTU settings download a program called DrTCP (google for it) then change the MTU size of your Internet connection, try 1465 and keep dropping it until you get a figure that works...
You can also check out xbox support site for more information on MTU settings here
Feb 23, 2010 | Arris SURFboard SBG900 Wireless Router...
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
I need to change my routers MTU settings
enter configuration (default ip @ is 192.168.
Access your router’s configuration http://192.168.0.1 (this is default)
user and password (dafault admin/ and blank nothing)
Then go to the WAN option select on the lower part the MTU value.
it's 1500
try a lower value 1482 for example, 1480...
hope it helps
feed back plz
Apr 02, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Cant connect to internect on xbox live
Well, first you need to run the CD they gave you.
Do all the steps.
Once its finished it will give you some extra choices on the side.
Click Manual Settings.
Follow the link.
Hopefully you can find it there.
I had a problem with my WEP key and thats how i fixed it.
i dont know what a mtu is though. sorry.
Dec 28, 2008 | Dynex DX-E401 Router
Dynex mtu
Browse to the router's setup page and in Basic setup you will see MTU, change it from auto or default to 1500.
setup page address is 192.168.2.1,
Look under basic setup page.
Please remember to rate all Techs who assist you for free :) Good luck, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | Dynex DX-E401 Router
MTU
What router is it?
Sep 29, 2008 | Dynex DX-E401 Router
Xbox live
You need to enter the router configuration. How you do this varies by model, but usually involves typing your gateway address into a web browser. Then, you need to assign your xbox an internal IP address and activate port triggering or forwarding (depending on the sophistication of your device) to send information on the designated ports to the Xbox.RICHARDM69
Sep 08, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
XBox 360 MTU Failed with Router
MTU of 1500 is the standard TCP/IP message length. Only MS Vista allows that to be changed dynamically. If your ISP uses 1500 then you need to use it too. Your Xbox protocol may be blocked by your ISP. You may want to give them a ring...
Jan 04, 2008 | Linksys Wireless-G Broadband Router
Dynex 4-Port Ethernet Broadband Router (DX-E402) Logo
407 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
